Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What recognitions does the Gemini GV have?
The Gemini GV has the following approvals: UL Recognition, cUL, CE for LVD, and CE for EMC.
