Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 24 Volt Keep Alive
24 Volt Keep Alive
A user can provide 24VDC to power the control circuitry in the event of AC power failure. With the 24 volt keep alive active communication diagnostics, position feedback, and other logic functions will be operational. The appropriate filtering and isolation is present to minimize corruption of this signal. This input is optional to the user as all drives can operate directly off of the AC line.
