Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Daisy chaining AR-C
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • Parker Electronic Motion and Control Division (EMC) - Industrial Products Warranty
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
Daisy chaining AR-C
Up to four units may be used in daisy chain with RS232. If more than four are required, use them in RS485 multi-drop mode. If RS232 is absolutely required, a RS232/RS485 converter may be purchased from B&B Electronics (815) 434-0846.
