Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Dynaserv Static Brake Option
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
The Dynaserv product line offers a static mechanical brake option for some of the "A" and "B" series Dynaserv motors. This failsafe brake is powered by 24VDC, 3 Amps. The holding torque is 20 Nm for the "B" motors and 100 Nm for the "A" motors. The brake adds approximately 50mm to the height of the "A" series motors and approximately 40mm to the height of the "B" series motors. Please contact the Applications Engineering Department to receive a copy of the exact dimensions.
This brake must be ordered at the time of the original Dynaserv purchase and it is not field installable. The static brake option is available only for the following Dynaservs:
DR SeriesDM Series
DR-1015BDM-1015B
DR-1030BDM-1030B
DR-1045BDM-1045B
DR-1060BDM-1060B
DR-1100ADM-1050A
DR-1150ADM-1100A
DR-1200ADM-1150A
DR-1300ADM-1200A
DR-1400A
DR-5030B
DR-5050B
DR-5070B
DR-5300A
DR-5400A
DR-5500A
The brake option is not available for the DM-1004B, DM-1004C, DR-1008B or any of the "E" series motors.
