Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Misc - Communication Protocols
Does the 6K support standard communication protocols like Telnet, FTP, HTTP, or IEEE?
No. The 6K’s ComServer is configurable either for RS232/RS485, or for Ethernet, whereby it uses standard TCP/IP functions from Microsoft’s Winsock library.
