Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Status Bits and Commanding a Velocity of Zero
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000-
      • AT6000 Auxiliary Cables
      • AT6000 Product Issues
      • AT6XXX
      • Backing up 6000 Programs
      • Bad DLL Calling Convention
      • DDE 6000 and Excel
      • HOMLVL command
      • Linker Error
      • Minimum files for AT card
      • Model 6201 Information
      • Motion Architect and WinRT
      • ReceiveFile method bug
      • What is WinRT anyway?
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products+
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
When given the commands V0 and GO1, the 6000 series products report back their status as follows:
In TASF the (at velocity) bit will never read at velocity (yes). The same goes for the at ratio bit in the TFSF commands. If a folrn is set to 0 the status will never be at ratio(yes).
These bits will evaluate true for other velocities and ratios as expected.
