Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base PK2 Part Number Change(5/9/97)
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
The CE marked (LVD) version of the PK2 drive voltage setting cannot be changed. Now there are two versions available: PK2/110V and PK2/230V. The input power voltage is now part of the model number and therefore needs to be specified on order.
Effective immediately, you will need to use the following part numbers when ordering:
PK2/110V for 110-120 VAC ( 10%) and
PK2/230V for 220-240 VAC ( 10%)
