Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Running more than 199 programs in 6000 Products
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000-
      • AT6000 Auxiliary Cables
      • AT6000 Product Issues
      • AT6XXX
      • Backing up 6000 Programs
      • Bad DLL Calling Convention
      • DDE 6000 and Excel
      • HOMLVL command
      • Linker Error
      • Minimum files for AT card
      • Model 6201 Information
      • Motion Architect and WinRT
      • ReceiveFile method bug
      • What is WinRT anyway?
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products+
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
The 6000 products are set up with a BCD program select mode that allows you to select 199 different programs. Although this was the maximum number of programs selectable by design, a way around this has been found to allow more programs to be selected.
It is noted that you can only run 199 programs through the BCD inputs, and that any number higher than 199 sends you into program #200. By using this anomaly, you can run up to the maximum number of programs (for many products this is 400, see the MEMORY command for a list by product). You can do this by writing a set of IF statements which look for the particular input pattern you are interested in once you jump into the 200th program.
