Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base OEM070 with Dynaserv
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
The encoder resolution range of the OEM070 is from 400 to 65532. With this ER set to 63488 - exactly 1/8 of the Dynaserv (507904) - a roundoff error will occur.
This error manifests itself as a noticeable drift in motor position after several moves. The solution is to set the Dynaserv drive to the same resolution as the OEM070 with the Dynaserv "on board" multiplier.
