Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cables - MPM to MPA or MP-FLX or BLOK or SFD Drive Cable Drawings
For MPM, MPA, MP-Flex, TBF, TBN, Blok and SFD cable drawings, see the corresponding chart within the this zip file:
MTS_Cables.zip
MPA
Resolver.........Chart 1
Encoder..........Chart 2
6 and 8 inch Resolver/Brake..........Chart 22
Resolver/Tach/Brake..........Chart 5
1.5 inch, 55mm, 2 inch, 2 3/4 inch Motor Resolver..........Chart 2
1.5 inch, 55mm, 2 inch, 2 3/4 inch Motor Resolver/Brake..........Chart 23
14 Gauge, 3 and 4 inch Motor..........Chart 9
14 Gauge, 3 and 4 inch Motor/Brake..........Chart 9
14 Gauge, 6 inch Motor..........Chart 20
12 Gauge, 6 inch Motor..........Chart 26
10 Gauge, 6 inch Motor..........Chart 8
8 Gauge, 6 inch Motor..........Chart 12
12 Gauge, 8 inch and 12 Motor..........Chart 113
10 Gauge, 8 inch and 12 Motor..........Chart 19
8 Gauge, 8 inch and 12 Motor..........Chart 21
6 Gauge, 8 inch..........Chart 79
4 Gauge, 8 inch and 12 Motor..........Chart 10
Controller Encoder..........Chart 4
TDC/EDC/VRP Controller Cables..........Chart 3
XDC 700/710 Controller Cables..........Chart 35
MP-FLX
Resolver..........Chart 251
6 and 8 inch Resolver/Brake..........Chart 252
Encoder..........Chart 32
6 and 8 inch Encoder/Brake..........Chart 110
1.5 inch, 55mm, 2 inch, 2 3/4 inch Motor Resolver..........Chart 255
1.5 inch, 55mm, 2 inch, 2 3/4 inch Motor Resolver/Brake..........Chart 254
1.5 inch, 55mm, 2 inch, 2 3/4 inch Motor Encoder..........Chart 256
1.5 inch, 55mm, 2 inch, 2 3/4 inch Motor Encoder/Brake..........Chart 253
14 Gauge, 3 and 4 inch Motor..........Chart 200
14 Gauge, 3 and 4 inch Motor/Brake..........Chart 202
14 Gauge, 6 inch Motor..........Chart 203
12 Gauge, 6 inch Motor..........Chart 204
10 Gauge, 6 inch Motor..........Chart 205
12 Gauge, 8 inch and 12 Motor..........Chart 206
10 Gauge, 8 inch and 12 Motor..........Chart 207
6 Gauge, 8 inch and 12 Motor..........Chart 79
J3, User I/O Cable Assemble..........Chart 118
J4, Resolver Feedback Cable..........Chart 119
TBF, TBN
Resolver/Therm, TBF/R..........Chart 83
1.5 inch, 55mm, 2 inch, 2 3/4 inch Motor Resolver/Therm, TBF/R..........Chart 82
Right Angle 1.5 inch, 55mm, 2 inch, 2 3/4 inch Motor Resolver/Therm, TBF/R..........Chart 86
1.5 inch, 55mm, 2 inch, 2 3/4 inch Encoder, TBN/I Velocity Mode..........Chart 93
1.5 inch, 55mm, 2 inch, 2 3/4 inch Encoder, TBN-I Torque Mode..........Chart 105
TBN Miscellaneous..........180-00122, 180-00081, 175-00069, 176-00104, 176-00106, 176-00108
Miscellaneous
MPA Oflex Resolver..........Chart 13
MPA Fan..........Chart 84
1.5 inch, 55mm, 2 inch, 2 3/4 inch Motor Encoder..........Chart 39
1.5 inch, 55mm, 2 inch, 2 3/4 inch Motor Encoder/Brake..........Chart 57
Oflex 3 and 4 inch Motor..........Chart 14
DSP Controller Cable..........Chart 28
PowerBlok
PowerBlok ENC/ 15 pin-D connector..........Chart 120
PowerBlok to IOF cable..........Chart 124
IndexBlok, DriveBlok, SpindleBlok - Sensorless Servo
3 and 4 inch Motor Cable..........Chart 9
3 and 4 inch Motor/Brake Cable..........Chart 24
SFD-230 Digital Drive
RES/Therm Cable..........Chart 123
ENC/Therm Cable..........Chart 122
2 inch Motor/RES/Brake Cable..........Chart 114
2 inch Motor/ENC/Brake..........Chart 128
SFD ENC Output Cable..........Chart 129
2/27/13jh zip has OCR pdf now, keywords added
5' 170-24003 170-24087
8' 170-24021 -
10' 170-24004 170-24041
15' 170-24005 170-24032
16' - -
20' 170-24001 170-24037
25' 170-24002 170-24035
30' 170-24006 170-24033
35' 170-24007 170-24088
40' 170-24008 170-24086
45' 170-24009 170-24040
50' 170-24010 170-24034
55' 170-24011 170-24089
60' 170-24012 170-24090
65' 170-24013 170-24091
70' 170-24014 170-24092
75' 170-24015 170-24043
80' 170-24016 170-24081
85' 170-24017 170-24093
90' 170-24018 170-24094
95' 170-24019 170-24095
100' 170-24020 170-24096
105' 170-24029 -
110' 170-24030 170-24212
115' 170-24042 -
120' 170-24028 -
125' 170-24026 -
150' 170-24031 -
175' 170-24031
200' 170-24023 -
250' 170-24027 -
300' 170-24024 -
RESITHERM WIRE LEADS
PIN WIRE WIRE
FUNCTION COLOR
U THERM BLK/WHT
N THERM BLUE/WHT
H SIN YELLOW
G COS GND BLACK
S COS RED
F SIN GND BLUE
R REF GND YEL/WHT
E REF RED/WHT
D RES SHLD DRAIN
A - -
B - -
C - -
J - -
K - -
L - -
M - -
P - -
T - -
NOTES:
MOISTURE
PROOF
170-24045
170-24046
170-24047
170-24098
170-24048
170-24022
170-24036
170-24049
170-24050
170-24071
170-24038
170-24072
170-24073
170-24074
170-24075
170-24044
170-24076
170-24077
170-24078
170-24079
170-24039
170-24215
170-24213
170-24214
2.5' 180-20030 - -
1 3 ' 180-20028 - -
PIN WIRE WIRE
FUNCTION COLOR
CDI 3.5' 180-20029 - - A <1>R RED
5 ' 180-20002 180-20051 180-20150 B <1>S BLACK
10' 180-20003 180-20052 180-20151 C <1>T BLUE
12' 180-20037 - - D PE GND GREEN
15' 180-20001 180-20053 180-20152 U THERM BLACK/WHT
20' 180-20004 180-20054 180-00005 N THERM BLUE/WHT
25' 180-20005 180-20055 180-20153 H SIN YELLOW
30' 180-20011 180-20056 180-00066
35' 180-20012 180-20057 180-20154
40 ' 180-20013 180-20058 180-20155
45' 180-20014 180-20059 180-20156
50' 180-20006 180-20060 180-00069
55' 180-20015 180-20061 180-20157
G COS GND BLACK
S COS RED
F SIN GND BLUE
R REF GND YEL/WHT
E REF RED/WHT
60' 180-20016 180-20062 180-00027 J RES SHLD DRAIN
65' 180-20017 180-20063 180-20158 K - -
70' 180-20018 180-20064 180-20159 L - -
75' 180-20007 180-20065 180-20160 M - -
80' 180-20019 180-20066 180-20161 P - -
85' 180-20020 180-20067 180-20162 T - -
90' 180-20021 180-20068 180-20163
95' 180-20022 180-20069 180-20164
100' 180-20008 180-20070 180-20165
105' 180-20025 180-20074 -
110' 180-20023 180-20075 -
115' 180-20026 180-20071 -
120' 180-20027 180-20073 -
6.00"
/ --( C~ ,---
\, e J
'" l:A ,/ ,-/ CD
8 9 · MOISTUREPROOF
CONNECTOR:
PT06W-14-18S(027)
(270-00050)
TOm MTR/RES CABLE ASSY ~~'rir~. CHART - 2
REVISIONS
REV.
E
F
G
H
J
K
L
DESCRIPTION
E.C .O. - 252
E.C.O. - 277
E.C.O. - 354
E.C .O. - 4 19
E.C.O. - 461
E.C.O. - 532
E.C.O. - 640
I
I
I 8 \
DATE
9/26/95
1/31/96
1/21/97
8/8/97
12/18/97
2/19/02
9/16/02
APPD.
SW
SW
SW
SS
SW
MS
LIN
''''----,~ RIGHT ANGLE
CONNECTOR:
135' - 180-20072
150' 180-20009 -
200' 180-20024 -
250' 180-20010 -
176-00001 5' CON-5
176- 00002 10' CON - 10
176- 00003 15' CON - 15
176-00004 20' CON-20
176-00005 25' CON-25
176- 00006 30' CON - 30
176-00007 35' CON-35
176-00008 40' CON-40
176-00009 45' CON - 45
176- 00010 50' CON - 50
176-00011 55' CON-55
176-00012 60' CON-60 4.0?Of.
176- 00013 65' CON - 65 A~fYp) 176-00014 70' CON-70
176-00015 75' CON-75 /~ 1/ 176-00016 80' CON - 80
176-00017 85' CON - 85
176-00018 90' CON-90
176-00019 95' CON-95
176- 00020 100' CON - 100
175-00003 5' ENC-5 REV. DESC RIPTION DATE APPD.
175-00023 6' ENC-6 ® r A E.C.O . - 189 2/3/94 CEW
175- 00021 8' ENC - 8 B E.C .O. - 192 3/ 15/94 CEW
C E.C .0 . - 196 5/ 1/94 CEW
D E.C.O . - 351 12/30/96 MS
E E.C .0 . - 479 6/4/98 LIN
175-00004 10' ENC-10
175-00005 15' ENC-15
175- 00001 20' ENC - 20
175- 00002 25' ENC - 25
175-00006 30' ENC - 30
175-00007 35' ENC - 35
175- 00008 40' ENC - 40
175-00009 45' ENC -45
175-00010 50' ENC-50
175- 00011 55' ENC - 55
175- 00012 60' ENC - 60
175-00013 65' ENC-65
175-0001 4 70' ENC - 70
175- 00015 75' ENC - 75
175-00016 80' ENC -80
o LENGTH ~lRQf./ 1,OOOf' r I A(f lPJ /j A{f:PJ ~A ~/,,; I 1I~ ~ ~: ~n -&_ ~ I U
175-00017 85' ENC -85
175- 00018 90' ENC- 90
175- 00019 95' ENC - 95
175-00020 100' ENC- 100
5' 172-00001 172-00021 172-00051 F 1 E.C.O. - 376 97 1 SW
10' 172-00002 172-00022 172-00052 G 1 E.C.O. - 477 98 1 SW
15' 172-00003 172-00023 172-00053 H 1 E.C.O. - 495 98 1 ELS
20' 172-00004 172-00024 172-00054 J 1 E.C.O. - 532 99 1 MS
25' 172-00005 172-00025 172-00055 K 1 E.C.O. - 584 02 1 LIN
30' 172-00006 172-00026 172-00056
35' 172-00007 172-00027 172-00057
40' 172-00008 172-00028 172-00058 e SEE NOTE #3
45 ' 172-00009 172-00029 172-00059
50' 172-00010 172-00030 172-00060
55' 172-00011 172-00031 172-00061 BRK (+) I =q ~~ 12 NOTE #3
60' 172-00012 172-00032 172-00062
65' 172-00013 172-00033 172-00063 DETAIL A
70' 172-00014 172-00034 172-00064
75' 172-00015 172-00035 172-00065
80' 172-00016 172-00036 172-00066
85' 172-00017 172-00037 172-00067
90' 172-00018 172-00038 172-00068
95' 172-00019 172-00039 172-00069
100' 172-00020 172-00040 172-00070
150' 172-00074 172-00075 172-00076
3 ' 180-14030 - -
3.5 ' 180-14080 - -
5 ' 180-14007 180-14041 180-14151
10' 180-14008 180-14042 180-14152
12' 180-14031 - -
15' 180-14001 180-14026 180-14153
20' 180-14002 180-14029 180-14154
25' 180-14003 180-14028 180-14155
30' 180-14009 180-14033 180-14156
35' 180-14010 180-14043 180-14157
40 ' 180-14011 180-14044 180-14158
45' 180-14012 180-14034 180-14159
50 ' 180-14004 180-14036 180-14160
55 ' 180-14013 180-14045 180-14161
60' 180-14014 180-14046 180-14162
65' 180-14015 180-14047 180-14163
70' 180-14016 180-14048 180-14164
75' 180-14005 180-14039 180-14165
80' 180-14017 180-14049 180-14166
85' 180-14018 180-14075 180-14167
90' 180-14019 180-14076 180-14168
95' 180-14020 180-14077 180-14169
100' 180-14006 180-14078 180-14170
110' 180-14023 - -
115' 180-14037 - -
120' 180-14024 - -
MOISTUREPROOF 125' 180-14025
150' 180-14027 180-14035 - 6 4 5
200' 180-14032 - - CONNECTOR:
250' 180-14021 - -
3 ' 180-14030 - -
3.5 ' 180-14080 - -
12' 180-14031 - -
110' 180-14023 - -
115' 180-14037 - -
120' 180-14024 - -
250' 180-14021 - -
5' 180-40001 180-40044 180-40021
10' 180-40002 180-40045 180-40022
15' 180-40003 180-40046 180-40023
20' 180- 40004 180- 40047 180-40036
25' 180-40005 180-40043 180-40024
30' 180-40006 180-40048 180-40025
35' 180-40007 180-40049 180-40026
40' 180-40008 180-40050 180-40027
45' 180- 40009 180- 40051 180-40028
50' 180- 40010 180- 40041 180- 40029
55' 180-40011 180-40052 180-40030
60' 180-40012 180-40053 180-40031
65' 180-40013 180-40054 180-40032
70' 180-40014 180-40042 180-40033
75' 180-40015 180- 40055 180-40035
80' 180-40016 180-40056 180-40034
85' 180-40017 180-40057 180-40037
90' 180-40018 180-40058 180-40038
95' 180-40019 180-40059 180-40039
100' 180-40020 180- 40060 180-40040
125' - - 180-40064
150' - - 180-40062
175' - - 180-40063
5' 180-80001 180-80021 180-80040
10' 180-80002 180-80022 180-80041
15' 180-80003 180- 80023 180-80042
20' 180- 80004 180-80024 180-80043
25' 180-80005 180- 80025 180-80044
30' 180-80006 180-80026 180-80045
35' 180-80007 180-80027 180-80046
40' 180-80008 180-80028 180-80047
45' 180-80009 180- 80029 180-80048
50' 180-80010 180- 80106 180-80123
55' 180-80011 180- 80030 180-80124
60' 180-80012 180-80031 180-80125
65' 180-80013 180-80032 180-80126 "
70' 180-80014 180-80033 180-80127
75' 180-80015 180-80034 180- 80128
80' 180-80016 180- 80035 180- 80 129
85' 180-80017 180-80036 180-80130
90' 180-80018 180-80037 180-801 31 95' 180-80019 180-80038 180-80132 ""
100' 180-80020 180- 80039 180 - 80133
5' 170-24051 170-24170
10' 170-24052 170-24171
15' 170-24053 170-24172
20' 170-24054 170-24173
25' 170-24055 170-24174
30' 170-24056 170-24175
32' - 170-24176
35' 170-24057 170-24177
40 ' 170-24058 170-24178
44' - 170-24179
45 ' 170-24059 170-24180
50' 170-24060 170-24181
55 ' 170-24061 170-24182
60' 170-24062 170-24183
65' 170-24063 170-24184
70' 170-24064 170-24185
75' 170-24065 170-24186
80' 170-24066 170-24187
85' 170-24067 170-24188
90' 170-24068 170-24189
95' 170-24069 170-24190
100' 170-24070 170-24191
170-24192
170-24193
170-24194
170-24195
170-24080
170-24196
170-24197
170-24198
170-24199
170-24200
170-24201
170-24202
170-24203
170-24204
170-24205
170-24206
170-24207
170-24208
170-24209
170-24210
180-14101 5 ' FLEX-MTR-3/4-14-5
180-14102 10' FLEX MTR 3/4-14-10
180-14103 15' FLEX-MTR-3/4-14-15
180-14104 20' FLEX-MTR-3/4-14-20
180-14105 25' FLEX MTR 3/4-14-25
180-14105 30' FLEX-MTR-3/4-14-30
180-14107 35' FLEX-MTR-3/4-14-35
180-14108 40' FLEX MTR 3/4 14 40
180-14109 45' FLEX-MTR-3/4-14-45
180-14110 50' FLEX-MTR-3/4-14-50
180-14111 55' FLEX MTR 3/4 14 55
180-14112 50' FLEX-MTR-3/4-14-50
180-14113 65' FLEX MTR 3/4-14-65
180-14114 70' FLEX MTR 3/4 14 70
180-14115 75' FLEX-MTR-3/4-14-75
180-14115 80' FLEX MTR 3/4-14-80
180-14117 85' FLEX-MTR-3/4-14-85
180-14118 90' FLEX-MTR-3/4-14-90
180-14119 95' FLEX MTR 3/4-14-95
180-14120 100' FLEX-MTR-3/4-14-100
172-00051 5
172-00052 10'
172-00053 15'
172-00054 20'
172-00055 25 '
172-00056 30'
172-00057 35'
172-00058 40'
172-00059 45'
172-00060 50'
172-00061 55'
172-00062 60'
172-00063 65'
172-00064 70'
172-00065 75'
172-00066 80'
172-00067 85'
172-00068 90'
172-00069 95'
172-00070 100'
NOTES:
CROSS
REFERENC E
PIN
RES/TAC H/H20 5
RES/TAC H/H20 10
RES/TAC H/H20 15
RES/TAC H/H20 20
RES/TAC H/H20-25
RES/TAC H/H20- 30
RES/TAC H/H20 35
RES/TAC H/H20 40
RES/TAC H/H20 45
RES/TAC H/H20 50
RES/TAC H/H20-55
RES/TAC H/H20-60
RES/TAC H/H20 65
RES/TAC H/H20 70
RES/TAC H/H20 75
RES/TAC H/H20 80
RES/TAC H/H20-85
RES/TAC H/H20-90
RES/TAC H/H20 95
RES/TAC H/H20 1
180-14151 5' MTR-3/4-H20-14-5
180-14152 10' MTR 3/4-H20-14-10
.50 B ~ 180-14153 15' MTR-3/4-H20-14-15
180-14154 20' MTR-3/4-H20-14-20
180-14155 25' MTR 3/4-H20-1 4-25 * 180-14156 30' MTR-3/4-H20-14-30
180-14157 35' MTR-3/4-H20-14-35 f---
180-14158 40' MTR-3/4-H20-14-40
180-14159 45' MTR-3/4-H20-14-45
180-14160 50' MTR-3/4-H20-14-50
180-14161 55' MTR-3/4-H20-14-55 e
180-14162 60' MTR-3/4-H20-14-60
180-14163 65' MTR-3/4-H20-14-65
180-14164 70' MTR-3/4-H20-14-70
180-14165 75' MTR-3/4-H20-14-75 tB
180-14166 80' MTR 3/4-H20-14-80
180-14167 85' MTR-3/4-H20-14-85
180-14168 90' MTR-3/4-H20-14-90
180 14169 95' MTR 3/4-H20-14-95
180-14170 100' MTR-3/4-H20-14-100
180 14152 10' MTR 3/4-H20-14-10
180 14155 25' MTR 3/4-H20-1 4-25 *
180-14169 95' MTR 3/4-H20-14-95
180-10051 5' MTR-4-10-5 REV. II DESC RIPTION II DATE II APPD.
180-10052 10' MTR-4-10-10 A I E.C.O . - 196 1 5 11 6 I 9 4 I C EW
180-10053 15' MTR-4-10-15
180-10054 20' MTR-4-10-20
180-10055 25' MTR-4-10-25
180-10056 30' MTR-4-10-30
180-10057 35' MTR - 4-1 0 - 35
180-10058 40' MTR-4-10-40 ~ LENGTH I A
180-10059 45' MTR-4-10-45
180-10060 50' MTR-4-10- 50
180-10061 55' MTR-4-10-55 1'~ 180-10062 60' MTR-4-10-60 APPROX.
180-10063 65' MTR-4-10-65 I 180-10064 70' MTR-4-10-70 O ~ ~ 'I , f-- ~I
180-10065 75' MTR-4-10-75
180-10066 80'
XXX - XXXXX I-- - -- - -- - -- -- ~ -I ,- ---- -
MTR-4-10-80 :J 180-10067 85' MTR-4-10-85 ~,
180-10068 90' MTR-4-10-90 I N~#lj 9 @~ ~l-L
180-10069 95' MTR-4-10-95 L:A 180-10070 100' MTR-4-1 0-1 00
5' 180-10100 180-10200 180-10091
10' 180-10101 180-10201 180-10092
15' 180-10102 180-10202 180-10093
20' 180-10103 180-10203 180-10094 ,,/'
25' 180-10104 180-10204 180-10095
30' 180-10105 180-10205 180-10096
35' 180-10106 180-10206 180-10097
40' 180-10107 180-10207 180-10098
45' 180-10108 180-10208 180-10099
50' 180-10109 180-10209 180-10140
55' 180-10110 180-10210 180-10141
60' 180-10111 180-10211 180-10142
65' 180-10112 180-10212 180-10143
70' 180-10113 180-10213 180-10144
75' 180-10114 180-10214 180-10145
80' 180-10115 180-10215 180-10146
85' 180-10116 180-10216 180-10147
90' 180-10117 180-10217 180-10148
95' 180-10118 180-10218 180-10149
100' 180-10119 180-10219 180-10172
5' 180-14051 180-14121 180-14201
10' 180-14052 180-14122 180-14202
15' 180-14053 180-14123 180- 14203
20' 180 - 14054 180-14124 180- 14204
25' 180-14055 180-141 25 180-1 4205
30' 180-14057 180-14072 180-14206
35' 180-14058 180-14126 180- 14207
40' 180-14059 180-14127 180- 14208
45' 180- 14060 180- 14128 180-14209
50' 180- 14056 180- 14073 180-1 4210
55' 180-14061 180-141 29 180-14211
60' 180-14062 180-14191 180-14212
65' 180-14063 180-14192 180- 14213
70' 180- 14064 180-14193 180-14214
75' 180-14065 180-14194 180-14215
80' 180-14066 180-14074 180-14216
85' 180-14067 180-14195 180-14217
90' 180- 14068 180-14196 180- 14218
95' 180-14069 180-14197 180- 14219
100' 180-14070 180-141 98 180-14220
150' 180-14071 - -
5' 180-80051 180-80201 180-80100
8' 180-80072 - -
10' 180-80052 180-80202 180-80101
12' 180- 80073 - -
15' 180-80053 180-80203 180- 80103
20' 180-80054 180-80204 180-80 109
25' 180-80055 180-80205 180-80108
30' 180-80056 180-80206 180-80104
35' 180- 80057 180- 80207 180-80110
40' 180- 80058 180-80208 180- 80111
45' 180-80059 180-80209 180-80112
50' 180-80060 180-80210 180-80105
55' 180-80061 180-80211 180-80113
60' 180-80062 180-802 12 180-80114
65' 180-80063 180-80213 180-80115
70' 180-80064 180-80214 180-80116
75' 180-80065 180-80215 180-80117
80' 180-80066 180-80216 180-80 118
85' 180-80067 180-80217 180-80119
90' 180-80068 180-80218 180-80120
95' 180-80069 180-80219 180-80121
100' 180- 80070 180-80220 180-80122
125' 180-80071 - -
150' 180-80134 - -
5' 185-00001 185-00076 185-00254
10' 185-00002 185-00077 185-00255
15' 185-00003 185-00078 185-00256
20' 185-00004 185-00079 185-00257
25' 185-00005 185-00080 185-00253
30' 185-00010 185-00081 185-00230
35' 185-00011 185-00082 185-00258
40' 185-00012 185-00083 185-00259
45' 185-00013 185-00084 185-00260
50' 185-00006 185-00085 185-00211
55' 185-00014 185-00086 185-00261
60' 185-00015 185-00087 185-00262
65' 185-00016 185-00088 185-00263
70' 185-00017 185-00089 185-00264
75' 185-00007 185-00090 185-00265
80' 185-00018 185-00091 185-00266
85' 185-00019 185-00092
90' 185-00020 185-00093
95' 185-00021 185-00094
100' 185-00008 185-00095
125' 185-00009 -
150' 185-00022 -
185-00267
185-00268
185-00269
185-00270
5' 185-00051 185-00232 185-00373
10' 185-00052 185-00233 185-00374
15' 185-00053 185-00234 185-00375
20' 185-00054 185-00235 185-00376
25' 185-00055 185-00236 185-00377
30' 185-00056 185-00237 185-00378
35' 185-00057 185-00238 185-00379
40 ' 185-00058 185-00239 185-00380
45 ' 185-00059 185-00240 185-00381
50' 185-00060 185-00241 185-00382
55 ' 185-00061 185-00242 185-00383
60' 185-00062 185-00243 185-00384
65' 185-00063 185-00244 185-00385
70' 185-00064 185-00245 185-00386
75' 185-00065 185-00246
80' 185-00066 185-00247
85' 185-00067 185-00248
90' 185-00068 185-00210
95' 185-00069 185-00249
100' 185-00070 185-00250
110' - 185-00252
140' 185-00047 -
180' 185-00071 -
185-00387
185-00388
185-00389
185-00390
185-00391
185-00392
chart24
5 ' 185-14001 185-14051 185-14171
10' 185-14002 185-14052 185-14172
12' 185-14022 - -
15' 185-14003 185-14053 185-14173
16' - - 185-14191
20' 185-14004 185-14054 185-14174
25' 185-14005 185-14055 185-14175
30' 185-14006 185-14056 185-14176
35' 185-14007 185-14057 185-14177
40 ' 185-14008 185-14058 185-14178
45' 185-14009 185-14059 185-14179
50' 185-14010 185-14060 185-14180
55' 185-14014 185-14061 185-14181
60' 185-14015 185-14062 185-14182
65' 185-14016 185-14063 185-14183
70' 185-14017 185-14064 185-14184
75' 185-14011 185-14065 185-14185
80' 185-14013 185-14066 185-14186
85' 185-14018 185-14067 185-14187
90' 185-14019 185-14068 185-14188
95' 185-14020 185-14069 185-14189
100' 185-14012 185-14070 185-14190
110' - 185-14043 -
150' 185-14021 - -
chart25
12' 185-14022 - -
16' - - 185-14191
110' - 185-14043 -
150' 185-14021 - -
chart26
5' 180-12051 180-12071 180-12091
10' 180-12052 180- 12072 180-12092
15' 180-12053 180-12073 180-12093
20' 180-12054 180-12074 180-12094
25' 180-12055 180-12075 180-12095
30' 180-12056 180-12076 180-12096
35' 180-12057 180-12077 180-12097
40' 180-12058 180-12078 180-12098
45' 180-12059 180-12079 180-12099
50' 180-12060 180-12080 180-12100
55' 180-12061 180-12081 180-12151
60' 180-12062 180-12082 180-12152
65' 180-12063 180-12083 180-12153
70' 180-12064 180-12084 180-12154
75' 180-12065 180-12085 180-1 2155
80' 180-12066 180-12086 180-1 2156
85' 180-12067 180-12087 180-12157
90' 180-12068 180-12088 180- 12158
95' 180-12069 180-12089 180-12159
100' 180-12070 180-12090 180-12160
chart27
180- 12001 5' MTR-3/4-12-5
180-12002 10'MTR-3/4-12-10
180- 12003 15' MTR-3/4-12-15
180-12004 20' MTR-3/4-12-20
180-12005 25' MTR-3/4-12-25
180-12005 30' MTR-3/4-12-30
180-12007 35' MTR-3/4-12-35
180-12008 40' MTR-3/4-12-40
180-12009 45' MTR-3/4-12-45
180-12010 50' MTR-3/4-12-50
180-12011 55' MTR-3/4-12-55
180-12012 50' MTR-3/4-12-50
180-12013 55' MTR-3/4-12-55
180-12014 70' MTR-3/4-12-70
180-12015 75' MTR-3/4-12-75
180-12015 80' MTR-3/4-12-80
180-12017 85' MTR-3/4-12-85
180-12018 90' MTR-3/4-12-90
180-12019 95' MTR-3/4-12-95
180-12020 100' MTR-3/4-12-100
chart28
176-00051 5' DSP-5
176-00052 10' DSP-10
176-00053 15' DSP-15
176-00054 20' DSP-20
176-00055 25' DSP-25
176-00056 30' DSP-30
176-00057 35' DSP-35
176-00058 40' DSP-40
176-00059 45' DSP-45
176-00060 50' DSP-50
chart29
FERRULE PI N GAGE
PI N
270-00119 LT. BLUE 24 2620.0 .41 .24 .03 .07 L-feArl~D
270-00120 TURQUOISE 22 2622 .0 .41 .24 .03 .09
270-00121 ORANGE 20 2397 .0 .50 .24 .05 .12
270-00122 YELLOW 18 2399.0 .50 .24 .07 .13 270-00123 RED 16 2204.0 .58 .32 .09 .15 --+- --+-~
270-00124 BLUE 14 2206 .0 .60 .32 .10 .17 , CJ j
270-00125 GRAY 12 2208.0 .63 .35 .13 .20
270-00126 BLACK 10 22 10.0 .79 .47 .15 .24
270-00127 IVORY 8 2212 .0 .85 .47 .19 .32
270-00128 BROWN 4 2267 .0 1.14 .63 .31 .46
chart30
185-00076 5' RES/BRK-RA-5
185-00077 10' RES/BRK-RA-l0
185-00078 15' RES/BRK-RA-15
185-00079 20' RES/BRK-RA-20
185-00080 25' RES/BRK-RA-25
185-00081 3D' RES/BRK-RA-30
185-00082 35' RES/BRK-RA-35
185 00083 40' RES/BRK-RA-40
185-00084 45' RES/BRK-RA-45
185-00085 50' RES/BRK-RA-50
185 00086 55' RES/BRK-RA-55
185-00087 60' RES/BRK-RA-60
185-00088 65 ' RES/BRK-RA-65
185 00089 70' RES/BRK-RA-70
185-00090 75' RES/BRK-RA-75
185-00091 80' RES/BRK-RA-80
185-00092 85' RES/BRK-RA-85
185-00093 90' RES/BRK-RA-90
185-00094 95' RES/BRK-RA-95
185-00095 100' RES/BRK-RA-l00
chart31
180-80201 5 ' MTR-RA-8-8-5
180-80202 10' MTR-RA-8-8-10
180-80203 15' MTR-RA-8-8-15
180-80204 20' MTR-RA-8-8-20
180-80205 25' MTR-RA-8-8-25
180-80206 30' MTR-RA-8-8-30
180-80207 35' MTR-RA-8-8-35
180 80208 40' MTR-RA-8-8-40
180-80209 45' MTR-RA-8-8-45
180-80210 50' MTR-RA-8-8-50
180 80211 55' MTR-RA-8-8-55
180-80212 60' MTR-RA-8-8-60
180-80213 65' MTR-RA-8-8-65
180 80214 70' MTR RA 8 8 70
180-80215 75' MTR-RA-8-8-75
180-80216 80' MTR-RA-8-8-80
180-80217 85' MTR-RA-8-8-85
180-80218 90' MTR-RA-8-8-90
180-80219 95' MTR-RA-8-8-95
180-80220 100' MTR-RA-8-8-100
chart32
5' 175-00100 175-00024 175-00121
10' 175-00101 175-00025 175-00122
12' 175-00055 - -
15' 175-00102 175-00026 175-00123
20' 175-00103 175-00027 175-00124
25' 175-00104 175-00028 175-00125
30' 175-00105 175-00029 175-00126
35' 175-00106 175-00030 175-00127
40' 175-00107 175-00031 175-00128
45' 175-00108 175-00032 175-00129
50' 175-00109 175-00059 175-00130
55' 175-00110 175-00033 175-00131
60' 175-00111 175-00034 175-00132
65' 175-00112 175-00035 175-00133
70' 175-00113 175-00036 175-00134
75' 175-00114 175-00037 175-00135
80' 175-00115 175-00038 175-00136
85' 175-00116 175-00039 175-00137
90' 175-00117 175-00040 175-00138
95' 175-00118 175-00041 175-00139
100' 175-00119 175-00042 175-00140
150' 175-00044 175-00061 -
250' 175-00047 - -
chart33
185-14051 5 ' MTR/BRK-RA-3/4-14-5
185-14052 10' MTR/BRK-RA-3/4-14-10
185-14053 15' MTR/BRK-RA-3/4-14-15
185-14054 20' MTR/BRK-RA-3/4-14-20
185-14055 25' MTR/BRK-RA-3/4-14-25
185-14056 30' MTR/BRK-RA-3/4-14-30
185-14057 35' MTR/BRK-RA-3/4-14-35
185 14058 40' MTR/BRK-RA-3/4-14-40
185-14059 45' MTR/BRK-RA-3/4-14-45
185-14060 50' MTR/BRK-RA-3/4-14-50
185 14061 55' MTR/BRK-RA-3/4-14-55
185-14062 60' MTR/BRK-RA-3/4-14-60
185-14063 65' MTR/BRK-RA-3/4-14-65
185 14064 70' MTR/BRK-RA-3/4-14-70
185-14085 75' MTR/BRK-RA-3/4-14-75
185-14066 80' MTR/BRK-RA-3/4-14-80
185-14067 85' MTR/BRK-RA-3/4-14-85
185-14068 90' MTR/BRK-RA-3/4-14-90
185-14069 95' MTR/BRK-RA-3/4-14-95
185-14070 100' MTR/BRK-RA-3/4-14-100
chart34
180 10033 5 MTR-RA-6-10-5
180 10034 10' MTR-RA-6-10-10
180 10032 15' MTR-RA-6-10-15
180- 10035 20' MTR-RA-6-10-20
180-10036 25' MTR-RA-6-10-25
180-10030 30' MTR-RA-6-10-30
180 10037 35' MTR-RA-6-10-35
180 10038 40' MTR-RA-6-10-40
180 10039 45' MTR-RA-6-10-45
180 10031 50' MTR RA 6 10 50
180-10040 55' MTR-RA-6-10-55
180 10041 60 ' MTR-RA-6-10-60
180 10042 65' MTR-RA-6-10-65
180 10043 70' MTR-RA-6-10-70
180 10044 75' MTR-RA-6-10-75
180-10045 80' MTR-RA-6-10-80
180- 10046 85' MTR-RA-6-10-85
180 10047 90' MTR-RA-6-10-90
180 10048 95' MTR-RA-6-10-95
180 10049 100' MTR-RA-6-10-100
chart35
176-00076 5' XDC-5
176-00096 8' XDC-8
176-00077 10' XDC-l0
176-00078 15' XDC-15
176-00079 20' XDC-20
176-00080 25' XDC-25
176-00081 30' XDC-30
176 00082 35' XDC 35
176-00083 40' XDC-40
176-00084 45' XDC-45
176 00085 50' XDC 50
176-00086 55' XDC-55
176-00087 60' XDC-60
176 00088 65' XDC-65
176-00089 70' XDC-70
176-00090 75' XDC-75
176-00091 80' XDC-80
176-00092 85' XDC-85
176-00093 90' XDC-90
176-00094 95' XDC-95
176-00095 100' XDC-l00
chart36
180-00034 5'
180-00035 10'
180-00036 12'
180-00037 15'
180-00038 20'
180-00039 25'
180-00040 30'
180-00041 40'
180-00042 50'
180-00043 100'
chart37
180-20051 5' MTR/RES-RA-2-5
180-20052 10' MTR/RES-RA-2-10
180-20053 15' MTR/RES-RA-2-15
180-20054 20' MTR/RES-RA-2-20
180-20055 25' MTR/RES-RA-2-25
180-20056 30' MTR/RES-RA-2-30
180-20057 35' MTR/RES-RA-2-35
180 20058 40' MTR/RES-RA-2-40
180-20059 45' MTR/RES-RA-2-45
180-20060 50' MTR/RES-RA-2-50
180 20061 55' MTR/RES-RA-2-55
180-20062 60' MTR/RES-RA-2-60
180-20063 65' MTR/RES-RA-2-65
180 20064 70' MTR/RES-RA-2-70
180-20065 75' MTR/RES-RA-2-75
180-20066 80' MTR/RES-RA-2-80
180-20067 85' MTR/RES-RA-2-85
180-20068 90' MTR/RES-RA-2-90
180-20069 95' MTR/RES-RA-2-95
180-20070 100' MTR/RES-RA-2-100
180-20074 105' MTR/RES-RA-2-105
180-20075 110' MTR/RES-RA-2-110
180-20071 115' MTR/RES-RA-2-115
180-20073 120' MTR/RES-RA-2-120
180-20072 135' MTR/RES-RA-2-135
chart38
170-24045 5 ' RES-H20-5
170-24046 10' RES-H20-10
170-24047 15' RES-H20-15
170-24098 16' RES-H20-16
170-24048 20' RES-H20-20
170-24022 25' RES-H20-25
170-24036 30' RES-H20-30
170 24049 35' RES H20 35
170-24050 40' RES-H20-40
170-24071 45' RES-H20-45
170 24038 50' RES H20 50
170-24072 55' RES-H20-55
170-24073 60' RES-H20-60
170 24074 65' RES H20 65
170-24075 70' RES-H20-70
170-24044 75' RES-H20-75
170-24076 80' RES-H20-80
170-24077 85' RES-H20-85
170-24078 90' RES-H20-90
170-24079 95' RES-H20-95
170-24039 100' RES-H20-100
chart39
180-00014 3'
180-00025 S'
180-00017 10'
180-00006 12'
180-000S4 IS'
180-000SS 20'
180-00029 2S'
180-00033 30'
180-000S6 3S'
180-00023 40'
180-000S7 4S'
180-00022 SO'
180-00527 60'
180-00068 7S
chart40
170-00035 3.5'
170-00050 4'
170-00046 5'
170-00036 10'
170-00051 11'
170-00052 13'
170-00047 14'
170-00042 15'
170-00053 16'
170 00048 20'
170-00049 25'
chart41
R 10 10' P24915-El0
R-15 15' P24915-E15
R 20 20' P24915 E20
R 25 25' P24915-E25
R-30 30' P24915-E30
R 35 35' P24915 E35
R 40 40' P24915-E40
R-45 45' P24915-E45
R 50 50' P24915 E50
R 55 55' P24915-E55
R-60 60' P24915-E60
R 65 65' P24915-E65
R 70 70' P24915-E70
R-75 75' P24915-E75
R 80 80' P24915-E80
R-85 85' P24915-E85
R 90 90' P24915-E90
R 95 95' P24915-E95
R-l00 100' P24915-El00
chart42
P-3/4-14-5 5' P24914-E5
P-3/4-14-10 10' P24914-E10
P-3/4-14-15 15' P24914-E15
P-3/4-14-20 20' P24914-E20
P-3/4-14-25 25' P24914-E25
P-3/4-14-30 30' P24914-E30
P-3/4-14-35 35' P24914-E35
P-3/4-14-40 40' P24914-E40
P-3/4-14-45 45' P24914-E45
P-3/4-14-50 50' P24914-E50
P-3/4-14-55 55' P24914-E55
P-3/4-14-60 60' P24914-E60
P-3/4-14-65 65' P24914-E65
P-3/4-14-70 70' P24914-E70
P-3/4-14-75 75' P24914-E75
P-3/4-14-80 80' P24914-E80
P-3/4-14-85 85' P24914-E85
P-3/4-14-90 90 ' P24914-E90
P-3/4-14-95 95' P24914-E95
P-3/4-14-100 100' P24914-E100
chart43
CE R C5 5'
CE/R-ClO 10'
CE/R C15 15'
CE/R C20 20'
CE/R C25 25 '
CE/R C30 30'
CE/R-C35 35'
CE/R-C40 40'
CE/R C45 45'
CE/R C50 50'
CE/R C55 55'
CE/R C60 60'
CE/R-C65 65'
CE/R-C70 70'
CE/R C75 75'
CE/R C80 80'
CE/R C85 85'
CE/R C90 90'
CE/R-C95 95'
CE/R-C100 100'
chart44
CE/P-8-12-10 10'
chart45
P-6-8-5 5' P25104-E5
P-6-8-10 10' P25104-El0
P-6-8-15 15' P25104-E15
P-6-8-20 20' P25104-E20
P-6-8-25 25' P25104-E25
P-6-8-30 30' P25104-E30
P-6-8-35 35' P25104-E35
P-6-8-40 40' P25104-E40
P-6-8-45 45' P25104-E45
P-6-8-50 50' P25104-E50
P-6-8-55 55' P25104-E55
P-6-8-60 60' P25104-E60
P-6-8-65 65' P25104-E65
P-6-8-70 70' P25104-E70
P-6-8-75 75' P25104-E75
P-6-8-80 80' P25104-E80
P-6-8-85 85' P25104-E85
P-6-8-90 90' P25104-E90
P-6-8-95 95' P25104-E95
P-6-8-100 100' P25104-El00
chart46
PRB-2-20-5 5'
PRB-2-20-10 10'
PRB-2-20-15 15'
PRB-2-20-20 20'
PRB-2-20-25 25'
PRB-2-20-30 30'
PRB-2-20-35 35'
PRB-2-20-40 40'
PRB-2-20-45 45'
PRB-2-20-50 50'
PRB-2-20-55 55'
PRB-2-20-50 50'
PRB-2-20-55 55'
PRB-2-20-70 70'
PRB-2-20-75 75'
PRB-2-20-80 80'
PRB-2-20-85 85'
PRB-2-20-90 90'
PRB-2-20-95 95'
PRB-2-20-100 100'
chart47
PB-3/4-14-5 5' P25136-E5
PB-3/4-14-10 10' P25136-E10
PB-3/4-14-15 15' P25136-E15
PB-3/4-14-20 20' P25136-E20
PB-3/4-14-25 25' P25136-E25
PB-3/4-14-30 30' P25136-E30
PB-3/4-14-35 35' P25136-E35
PB-3/4-14-40 40' P25136-E40
PB-3/4-14-45 45' P25136-E45
PB-3/4-14-50 50' P25136-E50
PB-3/4-14-55 55' P25136-E55
PB-3/4-14-60 60' P25136-E60
PB-3/4-14-65 65' P25136-E65
PB-3/4-14-70 70' P25136-E70
PB-3/4-14-75 75' P25136-E75
PB-3/4-14-80 80' P25136-E80
PB-3/4-14-85 85' P25136-E85
PB-3/4-14-90 90' P25136-E90
PB-3/4-14-95 95' P25136-E95
PB-3/4-14-100 100' P25136-E100
chart48
180-40021
180-40022
180-40023
180-40036
180-40024
180-40025
180-40026
180-40027
180-40028
180-40029
180-40030
180-40031
180-40032
180-40033
180-40035
180-40034
180-40037
180-40038
180-40039
180-40040
MTR-8-H20-4-5
MTR-8-H20-4-10
MTR-8-H20-4-15
MTR-8-H20-4-20
MTR-8-H20-4-25
MTR-8-H20-4-30
MTR-8-H20-4-35
MTR-8-H20-4-40
MTR-8-H20-4-45
MTR-8-H20-4-50
MTR-8-H20-4-55
MTR-8-H20-4-60
MTR-8-H20-4-65
MTR-8-H20-4-70
MTR-8-H20-4-75
MTR-8-H20-4-80
MTR-8-H20-4-85
MTR-8-H20-4-90
MTR-8-H20-4-95
MTR-8-H20-4-100
chart49
170-24087 5 ' RES-RA-5
170-24041 10' RES-RA-lO
170-24032 15' RES-RA-15
170-24037 20' RES-RA-20
170-24035 25' RES-RA-25
170-24033 30' RES-RA-30
170-24088 35' RES-RA-35
170 24085 40' RES RA 40
170-24040 45' RES-RA-45
170-24034 50' RES-RA-50
170 24089 55' RES RA 55
170-24090 50' RES-RA-50
170-24091 55' RES-RA-55
170 24092 70' RES RA 70
170-24043 75' RES-RA-75
170-24081 80' RES-RA-80
170-24093 85' RES-RA-85
170-24094 90' RES-RA-90
170-24095 95' RES-RA-95
170-24095 100' RES-RA-100
chart50
chart51
180-14041 5 ' MTR-RA-3/4-14-5
180-14042 10' MTR-RA-3/4-14-10
180-14026 15' MTR-RA-3/4-14-15
180-14029 20' MTR-RA-3/4-14-20
180-14028 25' MTR-RA-3/4-14-25
180-14033 30' MTR-RA-3/4-14-30
180-14043 35' MTR-RA-3/4-14-35
180 14044 40' MTR RA-3/ 4-14-40
180-14034 45' MTR-RA-3/4-14-45
180-14036 50' MTR-RA-3/4-14-50
180 14045 55' MTR RA-3/4-14-55
180-14046 60' MTR-RA-3/4-14-60
180-14047 65' MTR-RA-3/4-14-65
180 14048 70' MTR RA-3/4-14-70
180-14039 75' MTR-RA-3/4-14-75
180-14049 80' MTR-RA-3/4-14-80
180-14075 85' MTR-RA-3/4-14-85
180-14076 90' MTR-RA-3/ 4-14-90
180-14077 95' MTR-RA-3/4-14-95
180-14078 100' MTR-RA-3/4-14-100
180-14035 150' MTR-RA-3/4-14-150
chart 52
185-14171 5 ' MTR/BRK-3/4-H20-14-5
185-14172 10' MTR/BRK-3/4-H20-14-10
185-14173 15' MTR/BRK-3/4-H20-14-15
185-14191 16' MTR/BRK-3/4-H20-14-16
185-14174 20' MTR/BRK-3/4-H20-14-20
185-14175 25' MTR/BRK-3/4-H20-14-25
185-14176 30' MTR/BRK-3/4-H20-14-30
185 14177 35' MTR/BRK-3/4-H20-14-35
185-14178 40' MTR/BRK-3/4-H20-14-40
185-14179 45' MTR/BRK-3/4-H20-14-45
185 14180 50' MTR/BRK-3/4-H20-14-50
185-14181 55' MTR/BRK-3/4-H20-14-55
185-14182 60' MTR/BRK-3/4-H20-14-60
185 14183 65' MTR/BRK-3/4-H20-14-65
185-14184 70' MTR/BRK-3/4-H20-14-70
185-14185 75' MTR/BRK-3/4-H20-14-75
185-14186 80' MTR/BRK-3/4-H20-14-80
185-14187 85' MTR/BRK-3/4-H20-14-85
185-14188 90' MTR/BRK-3/4-H20-14-90
185-14089 95' MTR/BRK-3/4-H20-14-95
185-14190 100' MTR/BRK-3/4-H20-14-100
chart53
175- 00121 5' ENC-H20-5
175 00122 10' ENC-H20-10
175-00123 15' ENC-H20-15
175-00124 20' ENC-H20-20
175 00125 25' ENC-H20-25
175-00126 30' ENC-H20-30
175-00127 35' ENC-H20-35
175-00128 40' ENC-H20-40 E CH U PINK
175-00129 45' ENC-H20-45 R CH U\ TAN
175-00130 50' ENC -H2O-50 F CH V WHITE
175- 00131 55' ENC-H2O-55 S CH V GREEN
175-00132 60' ENC-H20-60 G CH W BRN/WHT
175-00133 65' ENC-H20-65 H CH W\ ORG/WHT
175-00134 70' ENC-H20-70 0 GND/CABLE DRAIN
175-00135 75' ENC-H20-75 L THERM ORANGE
175 00136 80' ENC-H20-80 A THERM BROWN
175-00137 85' ENC-H20-85
175-00138 90' ENC-H20-90
175 00139 95' ENC-H20-95
175-00140 100' ENC-H20-100
CHART54
180-20101 3' QFB2R-3
180-20102 5' QFB2R-5 B
180-20103 10' QFB2R-10
180-20104 12' OFB2R-12
180-20105 15' QFB2R-15
180-20106 20' QFB2R-20
180-20107 25' QFB2R-25
180-20108 30' QF82R-30
180-20109 35' QFB2R-35
180-20110 40' QFB2R-40
180-20111 45' QFB2R 45
180-20112 50' OFB2R-50
180-20113 75' QFB2R-75
180-20114 100' QFB2R-100
CHART55
CE/P-3/4-14-5 5'
CE/P-3/4-14-10 10'
CE/P-3/4-14-15 15'
CE/P-3/4-14-20 20'
CE/P-3/4-14-25 25 '
CE/P-3/4-14-30 30'
CE/P-3/4-14-35 35'
CE/P-3/4-14-40 40'
CE/P-3/4-14-45 45'
CE/P-3/4-14-50 50'
CE/P-3/4-14-55 55'
CE/P-3/4-14-60 60'
CE/P-3/4-14-65 65'
CE/P-3/4-14-70 70'
CE/P-3/4-14-75 75
CE/P-3/4-14-80 80'
CE/P-3/4-14-85 85'
CE/P-3/4-14-90 90'
CE/P-3/4-14-95 95'
CE/P-3/4-14-100 100'
CHART56
180-00506 5'
180-00507 10'
180-00508 20'
180-00503 25
180-00502 30'
180-00509 35'
180-00510 40'
180-00511 45'
180-00512 50'
180-00513 55'
180-00514 60'
180-00515 65'
180-00516 70'
180-00517 75'
180-00518 80'
180-00519 85'
180-00520 90'
180-00521 95'
180-00522 100'
CHART57
3' - - 185-00372
5' 185-00212 185-00393 185-00271
8' 185-00434 185-00435
10' 185-00213 185-00394 185-00272
12' 185-00204 - - ~
15' 185-00209 185-00395 185-00273
20' 185-00214 185-00396 185-00274
25' 185-00203 185-00397
30' 185-00215 185-00398
35' 185-00216 185-00399
40 ' 185-00217 185-00400
45' 185-00218 185-00401
50 ' 185-00205 185-00402
55 ' 185-00219 185-00403
185-00275
185-00276
185-00277
185-00278
185-00279
185-00280
185-00281
60' 185-00220 185-00404 185-00282
65' 185-00221 185-00405 185-00283 • MOISTUREPROOF
70' 185-00222 185-00406
75' 185-00223 185-00407
80' 185-00224 185-00408
85' 185-00225 185-00409
90' 185-00226 185-00410
95' 185-00227 185-00411
100' 185-00228 185-00412
185-00284 10
185-00285
185-00286
185-00287
185-00288
185-00289
185-00290
CHART58
5 '
8'
10'
15'
20'
25'
30'
35'
40'
45'
50'
55'
60'
65'
70'
75'
80'
85'
90'
95'
100'
180-20120
180-20140
180-20121
180-20122
180-20123
180-20124
180-20125
180-20126
180-20127
180-20128
180-20129
180-20130
180-20131
180-20132
180-20133
180-20134
180-20135
180-20136
180-20137
180-20138
180-20139
180-20142
180-20143
180-20141
chart59
180-00044 9.5' 810600-09
180 00073 6 .5 ' 810600-06
180-00074 4.5' 810600-04
180-00093 7.0' 810600-07
chart60
180-40044 5' MTR-RA-8-4-5
180 40045 10' MTR RA 8 4 10
180-40045 15' MTR-RA-8-4-15
180-40047 20' MTR-RA-8-4-20
180-40043 25' MTR-RA-8-4-25
180-40048 30' MTR-RA-8-4-30
180-40049 35' MTR-RA-8-4-35
180-40050 40' MTR-RA-8-4-40
180-40051 45' MTR-RA-8-4-45
180-40041 50' MTR-RA-8-4-50
180-40052 55' MTR-RA-8-4-55
180-40053 50' MTR-RA-8-4-50
180-40054 55' MTR-RA-8-4-55
180-40042 70' MTR-RA-8-4-70
180-40055 75' MTR-RA-8-4-75
180 40055 80' MTR-RA-8-4-80
180-40057 85' MTR-RA-8-4-85
180-40058 90' MTR-RA-8-4-90
180 40059 95' MTR RA 8 4 95
180-40050 100' MTR-RA-8-4-100
chart61
5' MTR-RA-6-8-5
10' MTR-RA-6-8-10
15' MTR-RA-6-8-15
- 20' MTR-RA-6-8-20
25' MTR-RA-6-8-25
30' MTR-RA-6-8-30
35' MTR-RA-6-8-35
40' MTR-RA-6-8-40
45' MTR-RA-6-8-45
180-80106 50' MTR-RA-6-8-50
55' MTR-RA-6-8-55
60' MTR-RA-6-8-60
65' MTR-RA-6-8-65
70' MTR-RA-6-8-70
- 75' MTR-RA-6-8-75
- 80' MTR-RA-6-8-80
85' MTR-RA-6-8-85
90' MTR-RA-6-8-90
95' MTR-RA-6-8-95
100' MTR-RA-6-8-100
chart62
180-18001 5 ' MTR/RES-18-5
180-18002 10' MTR/RES-18-10
180-18003 15' MTR/RES-18-15
180-18004 20' MTR/RES-18-20
180-18005 25' MTR/RES-18-25
180-18006 30' MTR/RES-18-30
180-18007 35' MTR/RES-18-35
180 18008 40' MTR/RES-18-40
180-18009 45' MTR/RES-18-45
180-18010 50' MTR/RES-18-50
180 18011 55' MTR/RES-18-55
180-18012 60' MTR/RES-18-60
180-18013 65' MTR/RES-18-65
180 18014 70' MTR/RES-18-70
180-18015 75' MTR/RES-18-75
180-18016 80' MTR/RES-18-80
180-18017 85' MTR/RES-18-85
180-18018 90' MTR/RES-18-90
180-18019 95' MTR/RES-18-95
180-18020 100' MTR/RES-18-100
chart63
172-00021 5 '
172-00022 10'
172-00023 15'
172-00024 20'
172-00025 25'
172-00026 30'
172-00027 35'
172-00028 40'
172-00029 45'
172-00030 50'
172-00031 55'
172-00032 60'
172-00033 65'
172-00034 70'
172-00035 75'
172-00036 80'
172-00037 85'
172-00038 90'
172-00039 95'
172-00040 100'
chart64
180-14086 3' QFB3R-3
180-14087 5' QFB3R-5
180-14088 10' QFB3R-l0
180 14089 12' QFB3R 12
180-14090 15' QFB3R-15
180-14091 20' QFB3R-20
180-14092 25' QFB3R-25
180-14093 30' QFB3R-30
180-14094 35' QFB3R-35
180-14095 40' QFB3R-40
180-14096 45' QFB3R-45
180-14097 50' QFB3R-50
180-14098 75' QFB3R-75
180-14099 100' QFB3R-l00
chart65
172-00100 5'
172-00101 10'
172-00102 15'
172-00XXX 20'
172-00XXX 25'
172-00XXX 30'
172-00XXX 35'
172-00XXX 40'
172-00XXX 45'
172-00XXX 50'
chart66
180-00194 2' OFB2-2
180-00083 5' OFB2-5
180-00085 10' OFB2-10
180-00079 12' OFB2-12
180-00086 15' OFB2-15
180-00087 20' OFB2-20
180-00080 25' OFB2-25
180-00088 30' OFB2-30
180-00089 35' OFB2-35
180-00090 40' OFB2-40
180-00091 45' OFB2-45
180-00084 50' OFB2-50
180-00185 75' OFB2-75
180-00077 100' OFB2 100
chart67
E-5 5' P25791-E5
E-l0 10' P25791-El0
E-15 15' P25791-E15
E-20 20' P25791-E20
E-25 25' P25791-E25
E-30 30' P25791-E30
E-35 35' P25791-E35
E-40 40' P25791-E40
E-45 45' P25791-E45
E-50 50' P25791-E50
E-55 55' P25791-E55
E-60 60' P25791-E60
E-65 65' P25791-E65
E-70 70' P25791-E70
E-75 75' P25791-E75
E-80 80' P25791-E80
E-85 85' P25791-E85
E-90 90' P25791-E90
E-95 95' P25791-E95
E-l00 100' P25791-El00
chart68
PE-2-18-5 5' P25792-E5
PE-2-18-10 10' P25792-E10
PE-2-18-15 15' P25792-E15
PE-2-18-20 20' P25792-E20
PE-2-18-25 25' P25792-E25
PE-2-18-30 30' P25792-E30
PE-2-18-35 35' P25792-E35
PE-2-18-40 40' P25792-E40
PE-2-18-45 45' P25792-E45
PE-2-18-50 50' P25792-E50
PE-2-18-55 55' P25792-E55
PE-2-18-60 60' P25792-E60
PE-2-18-65 65' P25792-E65
PE-2-18-70 70' P25792-E70
PE-2-18-75 75' P25792-E75
PE-2-18-80 80' P25792-E80
PE-2-18-85 85' P25792-E85
PE-2-18-90 90' P25792-E90
PE-2-18-95 95' P25792-E95
PE-2-18-100 100' P25792-E100
chart69
185-30001
185-30002
185-30003
185-30004
185-30005
185-30006
185-30007
185-30008
185-30009
185-30010
185-30011
185-30012
185-30013
185-30014
3' QBB3-3
5' QBB3-5
10' QBB3-10
12' QBB3-12
15' QBB3-15
20' QBB3-20
25' QBB3-25
30' QBB3-30
35' QBB3-35
40' QBB3-40
45' QBB3-45
50' QBB3-50
75' QBB3-75
100' QBB3-100
chart70
185-20051 3' QBB2-3
185- 20052 5' QBB2-5
185-20053 10' QBB2-10
185-20054 12' QBB2-12
185-20055 15' QBB2-15
185-20056 20' QBB2-20
185-20057 25' QBB2-25
185-20058 30' QBB2-30
185-20060 40' QBB2-40
185-20061 45' QBB2-45
185-20062 50' QBB2-50
185- 20063 75' QBB2-75
185-20064 100' QBB2-100
CHART71
180-80100 5' MTR-8-H20-8-5
180 80101 10' MTR 8 H20 8 10
180-80103 15' MTR-8-H20-8-15
180-80109 20' MTR-8-H20-8-20
180 80108 25' MTR 8 H20 8 25
180-80104 30' MTR-8-H20-8-30
180-80110 35' MTR-8-H20-8-35
180-80111 40' MTR-8-H20-8-40
180-80112 45' MTR-8-H20-8-45
180-80105 50' MTR-8-H20-8-50
180-80113 55' MTR-8-H20-8-55
180-80114 60' MTR-8-H20-8-60
180-80115 65' MTR-8-H20-8-65
180-80116 70' MTR-8-H20-8-70
180-80117 75' MTR-8-H20-8-75
180-80118 80' MTR-8-H20-8-80
180-80119 85' MTR-8-H20-8-85
180-80120 90' MTR-8-H20-8-90
180 80121 95' MTR 8 H20 8 95
180-80122 100' MTR-8-H20-8-100
CHART72
QFB3-3 5' QFB3-5
10' QFB3-10
180-14081 12' QFB3-12
15' QFB3-15
20' QFB3-20
180-14085 25' QFB3-25
30' QFB3-30
35' QFB3-35
40' QFB3-40
45' QFB3-45 180-14084
50' QFB3-50
75' QFB3-75
180-14082 100' QFB3-100
CHART73
180-20150 5 ' MTR/RES-2-H20-5
180-20151 10' MTR/RES-2-H20-10
180-20152 15' MTR/RES-2-H20-15
180-00005 20' MTR/RES-2-H20-20
180-20153 25' MTR/RES-2-H20-25
180-00066 30' MTR/RES-2-H20-30
180-20154 35' MTR/RES-2-H20-35
180 20155 40' MTR/RES-2-H20-40
180-20156 45' MTR/RES-2-H20-45
180-00069 50' MTR/RES-2-H20-50
180 20157 55' MTR/RES-2-H20-55
180-00027 60' MTR/RES-2-H20-60
180-20158 65' MTR/RES-2-H20-65
180 20159 70' MTR/RES-2-H20-70
180-20160 75' MTR/RES-2-H20-75
180-20161 80' MTR/RES-2-H20-80
180-20162 85' MTR/RES-2-H20-85
180-20163 90' MTR/RES-2-H20-90
180-20164 95' MTR/RES-2-H20-95
180-20165 100' MTR/RES-2-H20-100
CHART74
- 3' QFB3-3
- 5' QFB3-5 - 10' QFB3-10
- 15' QFB3-15
- 20' QFB3-20
- 30' QFB3-30
- 35' QFB3-35
- 40' QFB3-40
- 45' QFB3-45 180-14084
50' QFB3-50
- 75' QFB3-75
CHART75
CE/PR-2-20-5 5 ' -
CE/PR-2-20-10 10'
CE/PR-2-20-15 15' -
CE/PR-2-20-20 20' -
CE/PR-2-20-25 25'
CE/PR-2-20-30 30' -
CE/PR-2-20-35 35' -
CE/PR-2 20 40 40'
CE/PR-2-20-45 45' -
CE/PR-2-20-50 50' -
CE/PR-2 20 55 55'
CE/PR-2-20-60 60' -
CE/PR-2-20-65 65'
CE/PR-2 20 70 70'
CE/PR-2-20-75 75' -
CE/PR-2-20-80 80'
CE/PR-2-20-85 85' -
CE/PR-2-20-90 90' -
CE/PR-2-20-95 95'
CE/PR-2-20-100 100'
CHART76
175-00072 5'
175-00073 10'
175-00074 15'
175-00075 20'
175-00066 25'
175-00076 30'
175-000n 35'
175-00078 40'
175-00079 45'
175-00080 50'
175-00081 55'
175-00082 60'
175-00083 65'
175-00084 70'
175- 00085 75'
175-00086 80'
175-00087 85'
175-00088 90'
175-00089 95'
175-00090 100'
CHART77
170-00055 I 5'
170-00056 I 10'
170-00057 I 15'
RES/BRK/FAN-5
RES/BRK/FAN-10
RES/BRK/FAN-15
170-00058 I 20'
170-00059 I 25'
170-00025 I 30'
RES/BRK/FAN-20
RES/BRK/FAN-25
RES/BRK/FAN-30
170-00060 I 35' RES/BRK/FAN-35
170-00061 I 40' RES/BRK/FAN-40
170-00062 I 45' RES/BRK/FAN-45
170-00063 I 50'
170-00064 I 55' RES/BRK/FAN-55
170-00065 I 60' RES/BRK/FAN-60
170-00066 I 65' RES/BRK/FAN-65
170-00067 I 70'
170-00068 I 75'
RES/BRK/FAN-70
RES/BRK/FAN-75
170-00069 I 80' RES/BRK/FAN-80
170-00070 I 85' RES/BRK/FAN-85
170-00071 I 90' RES/BRK/FAN-90
170-00072 I 95' RES/BRK/FAN-95
170-00073 I 100' RES/BRK/FAN-100
CHART78
185-20070 3 ' QBB2R-3
185-20071 5' QBB2R-5
185-20072 10' QBB2R-l0
185-20073 12' QBB2R-12
185-20074 15' QBB2R-15
185-20075 20' QBB2R-20
185-20076 25' QBB2R-25
185 20077 30' QBB2R-30
185-20078 35' QBB2R-35
185-20079 40' QBB2R-40
185-20080 45' QBB2R-45
185-20081 50' QBB2R-50
185-20082 75' QBB2R-75
185-20083 100' QBB2R-100
CHART79
5' 180-60001 180-60021 180-60041
10' 180-60002 180-60022 180-60042
15' 180-60003 180-60023 180-60043
20' 180-60004 180-60024 180-60044
25' 180-60005 180-60025 180-60045
30' 180-60006 180-60026 180-60046
35' 180-60007 180-60027 180-60047
40' 180-60008 180-60028 180-60048
45' 180-60009 180-60029 180-60049
50' 180-60010 180-60030 180-60050
55' 180-60011 180-60031 180-60051
60' 180-60012 180-60032 180-60052
65' 180-60013 180-60033 180-60053
70' 180-60014 180-60034 180-60054
75' 180-60015 180-60035 180-60055
80' 180-60016 180-60036 180-60056
85' 180-60017 180-60037 180-60057
90' 180-60018 180-60038 180-60058
95' 180-60019 180-60039 180-60059
100' 180-60020 180-60040 180-60060
CHART82
180-20200 5 '
180-20201 10'
180-20202 15'
180-20203 20'
180-20204 25'
180-20205 30'
180-20206 35'
180-20207 40 '
180-20208 45 '
180-20209 50'
180-20210 55'
180-20211 60'
180-20212 65'
180-20213 70'
180-20214 75'
180-20215 80'
180-20216 85'
180-20217 90'
180-20218 95'
180-20219 100
CHART83
170-24101 5 '
170-24102 10'
170-24103 15'
170-24104 20'
170-24105 25'
170-24106 30'
170-24107 35'
170-24108 40'
170-24109 45'
170-24110 50'
170-24111 55'
170-24112 60'
170-24113 65'
170-24114 70'
170-24115 75'
170-24116 80'
170-24117 85'
170-24118 90'
170-24119 95'
170-24120 100'
CHART84
5' 185-00101 185-00141 -
10' 185-00102 185-00142 -
15' 185-00103 185-00143 -
20' 185-00104 185-00144 -
25' 185-00105 185-00145 -
30' 185-00106 185-00146 -
35' 185-00107 185-00147 -
40' 185-00108 185-00148 -
45' 185-00109 185-00149 -
50' 185-00110 185-00150 -
55' 185-00111 185-00151 -
60 ' 185-00112 185-00152 -
65' 185-00113 185-00153 -
70' 185-00114 185-00154 -
75' 185-00115 185-00155 -
80' 185-00116 185-00156 -
85' 185-00117 185-00157 -
90' 185-00118 185-00158 -
95' 185-00119 185-00159 -
100' 185-00120 185-00160 -
CHART85
185-00232 5'
185-00233 10'
185-00234 15'
185-00235 20'
185-00236 25'
185-00237 30'
185-00238 35'
185-00239 40'
185-00240 45'
185-00241 50'
185-00242 55'
185-00243 60'
185-00244 65'
185-00245 70'
185-00246 75'
185-00247 80'
185-00248 85'
185-00210 90'
185-00249 95'
185-00250 100'
185-00252 110'
460-00007
CHART86
180-20225 5'
180-20235 8'
180-20236 8.5'
180-20237 9 '
180-20238 9.5'
180-20226 10'
180-20239 10.5'
180-20227 15'
180-20228 20'
180-20229 25'
180-20230 30'
180-20231 35'
180-20232 40'
180-20233 45'
180-20234 50'
180-202XX 55'
180-202XX 60'
180-202XX 65'
180-202XX 70'
180-202XX 75'
CHART87
175-00150 5'
175-00151 10'
175-00152 15' -
175-00153 20' S231460
175-00154 25' -
175-00155 30' S231461
175-00156 35' -
175-00157 40' S231459
175-00158 45' -
175-00159 50' -
CHART88
CE/PB-3/4-14-5 5 '
CE/PB-3/4-14-10 10'
CE/PB-3/4-14-15 15'
CE/PB-3/4-14-20 20'
CE/PB-3/4-14-25 25'
CE/PB-3/4-14-30 30'
CE/PB-3/4-14-35 35'
CE/PB-3/4 14 40 40'
CE/PB-3/4-14-45 45'
CE/PB-3/4-14-50 50'
CE/PB-3/4 14 55 55'
CE/PB-3/4-14-50 50'
CE/PB-3/4-14-55 55'
CE/PB-3/4 14 70 70'
CE/PB-3/4-14-75 75'
CE/PB-3/4-14-80 80'
CE/PB-3/4-14-85 85'
CE/PB-3/4-14-90 90'
CE/PB-3/4-14-95 95'
CE/PB-3/4-14-100 100'
CHART89
180-14231 5 '
180-14232 10'
180-14233 15'
180-14234 20' S231457
180-14235 25' -
180-14236 30' S231458
180-14237 35' -
180-14238 40' -
180-14239 45' -
180-14240 50' -
180-14241 100' -
CHART90
180-00100 5'
180 00101 10'
180-00102 15'
180-00103 20'
180 00104 25'
180-00105 30'
180-00106 35'
180-00107 40'
180-00108 45'
180-00109 50'
180-00110 55'
180-00111 60'
180-00112 65'
180-00113 70'
180-00114 75'
180-00115 80'
180-00116 85'
180-00117 90'
180 00118 95'
180-00119 100'
CHART91
180-00XXX
180-00120
180-0009S
lS0-00121
lS0-00099
180-00XXX
180-00XXX
180-00XXX
180-00XXX
180-00XXX
180-00XXX
5'
8'
12'
13'
16'
20'
25'
30'
35'
40'
45'
CHART92
180-10200
180-10201
180-10202
180-10203
180-10204
180-10205
180-10206
180-10207
180-10208
180-10209
180-10210
180-10211
180-10212
180-10213
180-10214
180-10215
180-10216
180-10217
180-10218
180-10219
CHART93
180-20250 5'
180-20251 10'
180-20252 15'
180-20253 20'
180-20254 25'
180-20255 30'
180-20256 35'
180-20257 40'
180-20258 45'
180-20259 50'
180-20260 55'
180-20261 60'
180-20262 65'
180-20263 70'
180-20264 75'
180-20265 80'
180-20266 85'
180-20267 90'
180-20268 95'
180-20269 100'
CHART94
170-24130 5'
170-24131 10'
170-24132 15'
170-24133 20'
170-24134 25'
170-24135 30'
170-24136 35'
170-24137 40'
170-24138 45'
170-24139 50'
170-24140 55'
170-24141 60'
170-24142 65'
170-24143 70'
170-24144 75'
170-24145 80'
170-24146 85'
170-24147 90'
170-24148 95'
170-24149 100'
CHART99
185-00254 5 '
185-00255 10'
185-00256 15'
185-00257 20'
185-00253 25'
185-00230 30'
185-00258 35'
185-00259 40'
185-00260 45'
185-00211 50'
185-00261 55'
185-00262 60'
185-00263 65'
185-00264 70'
185-00265 75'
185-00266 80'
185-00267 85'
185-00268 90'
185-00269 95'
185-00270 100'
CHART100
185-00372 3'
185-00271 5'
185-00272 10'
185-00273 15'
185-00274 20'
185-00275 25'
185-00276 30'
185-00277 35'
185-00278 40'
185-00279 45'
185-00280 50'
185-00281 55'
185-00282 60 '
185-00283 65'
185-00284 70'
185-00285 75'
185-00286 80'
185-00287 85'
185-00288 90'
185-00289 95'
185-00290 100'
CHART101
176-00100 5 '
176-00101 10'
176-00102 15'
176-00103 20'
176-001XX 25'
176-001XX 3D'
176-001XX 35'
176-001XX 40'
176-001XX 45'
176-001XX 50'
176-001XX 55'
176-001XX 60'
176-001XX 65'
176-001XX 70'
176-001XX 75'
176-001XX 80'
176-001XX 85'
176-001XX 90'
176-001XX 95'
176-001XX 100'
CHART102
185-00291 5'
185-00292 10'
185-00293 15'
185-00294 20'
185-00295 25'
185-00296 30'
185-00297 35'
185-00298 40'
185-00299 45
185-00300 50'
185-00301 55'
185-00302 60 '
185-00303 65'
185-00304 70'
185-00305 75'
185-00306 80'
185-00307 85'
185-00308 90'
185-00309 95'
185-00310 100'
CHART103
175-00700 5'
175-00701 10'
175-00702 15'
175-00703 20'
175-00704 25'
175-00705 30'
175-00706 35'
175-00707 40'
175-00708 45'
175-00709 50'
175-00710 55'
175-00711 60'
175-00712 65'
175-00713 70'
175-00714 75'
175-00715 80'
175-00716 85'
175-00717 90'
175-00718 95'
175-00719 100'
CHART104
185-00312 5'
185-00313 10'
185-00314 15'
185-00315 20'
185-00316 25'
185-00317 30'
185-00318 35'
185-00319 40'
185-00320 45'
185-00321 50'
185-00322 55'
185-00323 60'
185-00324 65'
185-00325 70'
185-00326 75'
185-00327 80'
185-00328 85'
185-00329 90'
185-00330 95'
185-00331 100'
CHART105
180-20300 5'
180-20301 10'
180 20320 12'
180-20302 15'
180-20303 20'
180-20304 25'
180-20305 30'
180-20306 35'
180-20307 40'
180-20308 45'
180-20309 50'
180-20310 55'
180-20311 60'
180 20312 65'
180-20313 70'
180-20314 75'
180 20315 80'
180-20316 85'
180-20317 90'
180 20318 95'
180-20319 100'
chart110
5' 185-00333 185-00161
10' 185-00332 185-00162
15' 185-00334 185-00163
20' 185-00335 185-00164
25' 185-00336 185-00165
30' 185-00337 185-00166
35' 185-00338 185-00167
40 ' 185-00339 185-00168
45 ' 185-00340 185-00169
50' 185-00341 185-00170
55 ' 185-00342 185-00171
60' 185-00343 185-00172
65' 185-00344 185-00173
70' 185-00345 185-00174
75' 185-00346 185-00175
80' 185-00347 185-00176
85' 185-00348 185-00177
90' 185-00349 185-00178
95' 185-00350 185-00179
100' 185-00351 185-00180
150' 185-00497 -
185-00181
185-00182
185-00183
185-00184
185-00185
185-00186
185-00187
185-00188
185-00189
185-00190
185-00191
185-00192
185-00193
185-00194
185-00195
185-00196
185-00197
185-00198
185-00199
185-00200
chart111
185-00352 5'
185-00353 10'
185-00354 15'
185-00355 20'
185-00356 25 '
185-00357 30'
185-00358 35'
185-00359 40'
185-00360 45 '
185-00361 50'
185-00362 55'
185-00363 60 '
185-00364 65 '
185-00365 70'
185-00366 75 '
185-00367 80'
185-00368 85'
185-00369 90'
185-00370 95 '
185-00371 100'
chart112
180-20275 5'
180-20276 10'
180-20277 15'
180-00278 20'
180-20279 25'
180-20280 30'
180-20281 35'
180-20282 40'
180-20283 45'
180-20284 50'
180-20285 55'
180-20286 60'
180-20287 65'
180-20288 70'
180-20289 75'
180-20290 80'
180-20291 85'
180-20292 90'
180-20293 95'
180-20294 100'
chart113
5' 180-12161 180-12181 180-12201
10' 180-12162 180-12182 180-12202
15' 180-12163 180-12183 180-12203
20' 180-12164 180-12184 180-12204
25' 180-12165 180-12185 180-12205
30' 180-12166 180-12186 180-12206
35' 180-12167 180-12187 180-12207
40 ' 180-12168 180-12188 180-12208
45 ' 180-12169 180-12189 180-12209
50 ' 180-12170 180-12190 180-12210
55 ' 180-12171 180-12191 180-12211
60' 180-12172 180-12192 180-12212
65' 180-12173 180-12193 180-12213
70' 180-12174 180-12194 180-12214
75' 180-12175 180-12195 180-12215
80 ' 180-12176 180-12196 180-12216
85' 180-12177 180-12197 180-12217
90' 180-12178 180-12198 180-12218
95' 180-12179 180-12199 180-12219
100' 180-12180 180-12200 180-12220
chart114
l ' 180-00197
5' 180-00123
10' 180-00124
15' 180-00125
20' 180-00126
25' 180-00127
30' 180-00128
35' 180-00129
40' 180-00130
45' 180-00131
50' 180-00132
55' 180-00133
60' 180-00134
65' 180-00135
70' 180-00136
75' 180-00137
80' 180-00138
85' 180-00139
90' 180-00140
95' 180-00141
100' 180-00142
chart 115
175-00166
175-00167
175-00168
175-00169
175-00170
175-00171
175-00172
175-00173
175-00174
175-00175
175-00176
175-00177
175-00178
175-00179
175-00180
175-00181
175-00182
175-00183
175-00184
175-00185
chart116
170-00082
170-00034
chart117
5' 180-12101
10' 180-12102
15' 180-12103
20' 180-12104
25' 180-12105
30' 180-12106
35' 180-12107
40' 180-12108
45' 180-12109
50 ' 180-12110
chart118
175-00186 5'
175-00187 10'
175-00188 15'
175-00189 20'
175- 00190 25'
175-00191 30' 2 3
175-00192 35'
175-00193 40'
175-00194 45'
175-00195 50'
175-00196 55'
175-00197 60'
175-00198 65'
175-00199 70'
175-00200 75'
175-00201 80'
175-00202 85'
175-00203 90'
175-00204 95'
175-00205 100'
chart 119
170-00088 5'
170-00089 10'
170-00090 15'
170-00091 20'
170-00092 25'
170-00093 30'
170-00094 35'
170-00095 40'
170-00096 45'
170-00097 50'
170-00098 55'
170-00099 60'
170-00100 65'
170-00101 70'
170-00102 75'
170-00103 80'
170-00104 85'
170-00105 90'
170-00106 95'
170-00107 100'
chart120
175-00206 5'
175-00207 10'
175-00208 15'
175-00209 20'
175-00210 25'
175-00211 30'
175-00212 35'
175-00213 40'
175-00214 45'
175-00215 50'
175-00216 55'
175-00217 60'
175-00218 65'
175-00219 70'
175-00220 75'
175-00221 80'
175-00222 85'
175-00223 90'
175-00224 95'
175-00225 100'
chart121
175-00142 5'
175-00097 10'
175-00091 15'
175-00143 20'
175-00144 25'
175-00093 30'
175-00145 35'
175-00141 40'
175-00146 45'
175-00147 50'
175-00148 55'
175- 00149 60'
chart122
175-00226 3'
175-00227 5'
175-00228 10'
175-00229 15'
175-00230 20'
175-00231 25'
175-00232 30'
175-00233 35'
175-00234 40'
175-00235 45'
175-00236 50'
175-00237 55'
175-00238 60'
175-00239 65 '
175-00240 70'
175-00241 75'
175-00242 80'
175-00243 85'
175-00244 90'
175-00245 95'
175-00246 100'
chart123
185-00436 3'
185-00437 5'
185-00438 10'
185-00439 15'
185-00440 20'
185-00441 25'
185-00442 30'
185-00443 35'
185-00444 40'
185-00445 45'
185-00446 50'
185-00447 55'
185-00448 60'
185-00449 65'
185-00450 70'
185-00451 75'
185-00452 80'
185-00453 85'
185-00454 90'
185-00455 95'
185-00456 100'
chart124
195-000S9
195-00090
4120-4120-06-B
4120-4120-10-B
chart128
180-20330 5'
180-20331 10'
180-20332 15'
180-20333 20'
180-20334 25 '
180-20335 30'
180-20336 35'
180-20337 40'
180-20338 45'
180-20339 50 '
180-20340 55'
180-20341 60'
180-20343 70'
180-20344 75'
180-20345 80'
180-20346 85'
180-20347 90'
180-20348 95'
180-20349 100'
chart129
175-00250 5'
175-00251 10'
175-00252 15'
175-00253 20'
175-00254 25'
175-00255 30'
175-00256 35'
175-00257 40'
175-00258 45'
175-00259 50'
chart130
185-00490 5'
185-00460 10'
185-00491 15'
185-00492 20'
185-00493 25'
185-00494 30'
185-00495 40'
185-00048 50'
185-00461 65'
185-00488 75'
185-00049 120'
chart 131
6' 170-00078
15' 170-00109
50 ' 170-00110
60' 170-00111
chart 132
170 00117 5'
170-00118 10'
170-00113 15'
170-00119 20'
170-00114 25'
170-00120 30'
170-00121 35'
170-00122 40'
170-00123 45'
170-00124 50'
170-00125 55'
170 00126 60'
170-00127 65'
170-00128 70
170 00129 75'
170-00130 80'
170-00131 85'
170 00132 90'
170-00133 95'
170-00134 100'
chart133
5' 185 00467
10' 185-00468
15' 185-00469
20' 185-00470 - -
25' 185-00471
30 ' 185 00472
35' 185-00473
40' 185-00474
45' 185-00475
50 ' 185-00476
55 ' 185 00477
60' 185-00478
65' 185-00479
70' 185-00480
185-00481
75 ' , ,
80 ' 185 00482
85' 185-00483 - -
90' 185-00484 - -
95' 185-00485 - -
100' 185-00486
chart 134
5' 180-18021-1 180-18021-2 180-18021-3
10' 180-18022-1 180-18022-2 180-18022-3
15' 180-18023-1 180-18023-2 180-18023-3
20' 180-18024-1 180-18024-2 180-18024-3
25' 180-18025-1 180-18025-2 180-18025-3
30' 180-18026-1 180-18026-2 180-18026-3
35' 180-18027-1 180-18027-2 180-18027-3
40 ' 180-18028-1 180-18028-2 180-18028-3
45 ' 180-18029-1 180-18029-2 180-18029-3 6
50 ' 180-18030-1 180-18030-2 180-18030-3
55 ' 180-18031-1 180-18031-2 180-18031-3
60' 180-18032-1 180-18032-2 180-18032-3
65' 180-18033-1 180-18033-2 180-18033-3
70' 180-18034-1 180-18034-2 180-18034-3
75' 180-18035-1 180-18035-2 180-18035-3
80' 180-18036-1 180-18036-2 180-18036-3
85' 180-18037-1 180-18037-2 180-18037-3
90' 180-18038-1 180-18038-2 180-18038-3
95' 180-18039-1 180-18039-2 180-18039-3
100' 180-18040-1 180-18040-2 180-18040-3
chart135
185-00500 5'
185-00501 10'
185-00502 15'
185-00503 20'
185-00504 25'
185-00505 30'
185-00506 35'
185-00507 40'
185-00508 45'
185-00509 50'
185-00510 55'
185-00511 60'
185-00512 65'
185-00513 70'
185-00514 75'
185-00515 80'
185-00516 85'
185-00517 90'
185-00518 95'
185-00519 100'
chart136
175-00262 5'
175-00263 10'
175-00264 15'
175-00265 20'
175-00266 25'
175-00267 30'
175-00268 35'
175-00269 40'
175-00270 45'
175-00271 50'
175-00272 55'
175-00273 60'
175-00274 65'
175-00275 70'
175-00276 75'
175-00277 80'
175-00278 85'
175-00279 90'
175-00280 95'
175-00281 100'
chart137
185-00520 5'
185-00521 10'
185-00522 15'
185-00523 20'
185-00524 25'
185-00525 30'
185-00526 35'
185-00527 40'
185-00528 45 '
185-00529 50'
185-00530 55'
185-00531 60'
185-00532 65'
185-00533 70'
185-00534 75 '
185-00535 80'
185-00536 85'
185-00537 90'
185-00538 95 '
185-00539 100'
chart138
5 ' 180-00217
10' 180-00218
15' 180-00219
20' 180-00220
25' 180-00221
30' 180-00222
35' 180-00223
40' 180-00224
45' 180-00225
50' 180-00226
55' 180-00227
60' 180-00228
65' 180-00229
70' 180-00230
75' 180-00231
80' 180-00232
85' 180-00233
90' 180-00234
95' 180-00235
100' 180-00236
chart200
5' 180-14251-1 180-14251-2 180-14251-3
10' 180-14252-1 180-14252-2 180-14252-3
15' 180-14253-1 180-14253-2 180-14253-3
20' 180-14254-1 180-14254-2 180-14254-3
25' 180-14255-1 180-14255-2 180-14255-3
30' 180-14256-1 180-14256-2 180-14256-3
35' 180-14257-1 180-14257-2 180-14257-3
40' 180-14258-1 180-14258-2 180-14258-3
45' 180-14259-1 180-14259-2 180-14259-3
50' 180-14260-1 180-14260-2 180-14260-3
55' 180-14261-1 180-14261-2 180-14261-3
60' 180-14262-1 180-14262-2 180-14262-3
65' 180-14263-1 180-14263-2 180-14263-3
70' 180-14264-1 180-14264-2 180-14264-3
75' 180-14265-1 180-14265-2 180-14265-3
80' 180-14266-1 180-14266-2 180-14266-3
85' 180-14267-1 180-14267-2 180-14267-3
90' 180-14268-1 180-14268-2 180-14268-3
95' 180-14269-1 180-14269-2 180-14269-3
100' 180-14270-1 180-14270-2 180-14270-3
chart201
5' 180-12022-1 180-12022-2 180-12022-3
10' 180-12023-1 180-12023-2 180-12023-3
15' 180-12024-1 180-12024-2 180-12024-3
20' 180-12025-1 180-12025-2 180-12025-3
25' 180-12026-1 180-12026-2 180-12026-3
30' 180-12027-1 180-12027-2 180-12027-3
35' 180-12028-1 180-12028-2 180-12028-3
40' 180-12029-1 180-12029-2 180-12029-3
45' 180-12030-1 180-12030-2 180-12030-3
50' 180-12031-1 180-12031-2 180-12031-3
55' 180-12032-1 180-12032-2 180-12032-3
60' 180-12033-1 180-12033-2 180-12033-3
65' 180-12034-1 180-12034-2 180-12034-3
70' 180-12035-1 180-12035-2 180-12035-3
75' 180-12036-1 180-12036-2 180-12036-3
80' 180-12037-1 180-12037-2 180-12037-3
85' 180-12038-1 180-12038-2 180-12038-3
90' 180-12039-1 180-12039-2 180-12039-3
95' 180-12040-1 180-12040-2 180-12040-3
100' 180-12041-1 180-12041-2 180-12041-3
chart202
180-14023-1 180-14023-2
180-14024-1 180-14024-2
180-14025-1 180-14025-2
180-14026-1 180-14026-2
180-14027-1 180-14027-2
180-14028-1 180-14028-2
180-14029-1 180-14029-2
180-14030-1 180-14030-2
180-14031-1 180-14031-2
180-14032-1 180-14032-2
180-14033-1 180-14033-2
180-14034-1 180-14034-2
180-14035-1 180-14035-2
180-14036-1 180-14036-2
180-14037-1 180-14037-2
180-14038-1 180-14038-2
180-14039-1 180-14039-2
180-14040-1 180-14040-2
180-14041-1 180-14041-2
180-14042-1 180-14042-2
180-14023-3
180-14024-3
180-14025-3
180-14026-3
180-14027-3
180-14028-3
180-14029-3
180-14030-3
180-14031-3
180-14032-3
180-14033-3
180-14034-3
180-14035-3
180-14036-3
180-14037-3
180-14038-3
180-14039-3
180-14040-3
180-14041-3
180-14042-3
chart203
5' 180-14131-1 180-14131-2 180-14131-3
10' 180-14132-1 180-14132-2 180-14132-3
15' 180-14133-1 180-14133-2 180-14133-3
20' 180-14134-1 180-14134-2 180-14134-3
25' 180-14135-1 180-14135-2 180-14135-3
30' 180-14136-1 180-14136-2 180-14136-3
35' 180-14137-1 180-14137-2 180-14137-3
40' 180-14138-1 180-14138-2 180-14138-3
45' 180-14139-1 180-14139-2 180-14139-3
50' 180-14140-1 180-14140-2 180-14140-3
55' 180-14141-1 180-14141-2 180-14141-3
60' 180-14142-1 180-14142-2 180-14142-3
65 ' 180-14143-1 180-14143-2 180-14143-3
70' 180-14144-1 180-14144-2 180-14144-3
75' 180-14145-1 180-14145-2 180-14145-3
80' 180-14146-1 180-14146-2 180-14146-3
85' 180-14147-1 180-14147-2 180-14147-3
90' 180-14148-1 180-14148-2 180-14148-3
95' 180-14149-1 180-14149-2 180-14149-3
100' 180-14150-1 180-14150-2 180-14150-3
chart204
180-12111-1 180-12111-2 180-12111-3
180-12112-1 180-12112-2 180-12112-3
180-12113-1 180-12113-2 180-12113-3
180-12114-1 180-12114-2 180-12114-3
180-12115-1 180-12115-2 180-12115-3
270-00118
30' 180-12116-1 180-12116-2 180-12116-3
35' 180-12117-1 180-12117-2 180-12117-3
40' 180-12118-1 180-12118-2 180-12118-3
45' 180-12119-1 180-12119-2 180-12119-3
50' 180-12120-1 180-12120-2 180-12120-3
55' 180-12121-1 180-12121-2 180-12121-3
60' 180-12122-1 180-12122-2 180-12122-3
65 ' 180-12123-1 180-12123-2 180-12123-3
70' 180-12124-1 180-12124-2 180-12124-3
75' 180-12125-1 180-12125-2 180-12125-3
80' 180-12126-1 180-12126-2 180-12126-3
85' 180-12127-1 180-12127-2 180-12127-3
90' 180-12128-1 180-12128-2 180-12128-3
95' 180-12129-1 180-12129-2 180-12129-3
100' 180-12130-1 180-12130-2 180-12130-3
175' 180-12221-1 180-12221-2 180-12221-3
chart205
5' 180-10120-1 180-10120-2 180-10120-3
10' 180-10121-1 180-10121-2 180-10121-3
15' 180-10122-1 180-10122-2 180-10122-3
20' 180-10123-1 180-10123-2 180-10123-3
25' 180-10124-1 180-10124-2 180-10124-3
30' 180-10125-1 180-10125-2 180-10125-3
35' 180-10126-1 180-10126-2 180-10126-3
40' 180-10127-1 180-10127-2 180-10127-3
45' 180-10128-1 180-10128-2 180-10128-3
50' 180-10129-1 180-10129-2 180-10129-3
 55' 180-10130-1 180-10130-2 180-10130-3
60' 180-10131-1 180-10131-2 180-10131-3
65 ' 180-10132-1 180-10132-2 180-10132-3
70' 180-10133-1 180-10133-2 180-10133-3
75' 180-10134-1 180-10134-2 180-10134-3
80' 180-10135-1 180-10135-2 180-10135-3
85' 180-10136-1 180-10136-2 180-10136-3
90' 180-10137-1 180-10137-2 180-10137-3
95' 180-10138-1 180-10138-2 180-10138-3
100' 180-10139-1 180-10139-2 180-10139-3
chart206
5' 180-12131-1 180-12131-2 180-12131-3
10' 180-12132-1 180-12132-2 180-12132-3
15' 180-12133-1 180-12133-2 180-12133-3
20' 180-12134-1 180-12134-2 180-12134-3
25' 180-12135-1 180-12135-2 180-12135-3
30' 180-12136-1 180-12136-2 180-12136-3
35' 180-12137-1 180-12137-2 180-12137-3
40' 180-12138-1 180-12138-2 180-12138-3
45' 180-12139-1 180-12139-2 180-12139-3
50' 180-12140-1 180-12140-2 180-12140-3
55' 180-12141-1 180-12141-2 180-12141-3
60' 180-12142-1 180-12142-2 180-12142-3
65' 180-12143-1 180-12143-2 180-12143-3
70' 180-12144-1 180-12144-2 180-12144-3
75' 180-12145-1 180-12145-2 180-12145-3
80' 180-12146-1 180-12146-2 180-12146-3
85' 180-12147-1 180-12147-2 180-12147-3
90' 180-12148-1 180-12148-2 180-12148-3
95' 180-12149-1 180-12149-2 180-12149-3
100' 180-12150-1 180-12150-2 180-12150-3
chart207
5' 180-10152-1 180-10152-2 180-10152-3
10' 180-10153-1 180-10153-2 180-10153-3
15' 180-10154-1 180-10154-2 180-10154-3
20' 180-10155-1 180-10155-2 180-10155-3
25' 180-10156-1 180-10156-2 180-10156-3
30' 180-10157-1 180-10157-2 180-10157-3
35' 180-10158-1 180-10158-2 180-10158-3
40' 180-10159-1 180-10159-2 180-10159-3
45' 180-10160-1 180-10160-2 180-10160-3
50' 180-10161-1 180-10161-2 180-10161-3
55' 180-10162-1 180-10162-2 180-10162-3
60' 180-10163-1 180-10163-2 180-10163-3
65' 180-10164-1 180-10164-2 180-10164-3
70' 180-10165-1 180-10165-2 180-10165-3
75' 180-10166-1 180-10166-2 180-10166-3
80' 180-10167-1 180-10167-2 180-10167-3
85' 180-10168-1 180-10168-2 180-10168-3
90' 180-10169-1 180-10169-2 180-10169-3
95' 180-10170-1 180-10170-2 180-10170-3
100' 180-10171-1 180-10171-2 180-10171-3
250' 180-10173-1 180-10173-2 180-10173-3
chart251
5' 170-24150-1 170-24150-2 170-24150-3
10' 170-24151-1 170-24151-2 170-24151-3
15' 170-24152-1 170-24152-2 170-24152-3
20' 170-24153-1 170-24153-2 170-24153-3
25' 170-24154-1 170-24154-2 170-24154-3
30' 170-24155-1 170-24155-2 170-24155-3
35' 170-24156-1 170-24156-2 170-24156-3
40' 170-24157-1 170-24157-2 170-24157-3
45' 170-24158-1 170-24158-2 170-24158-3
50' 170-24159-1 170-24159-2 170-24159-3
55' 170-24160-1 170-24160-2 170-24160-3
60' 170-24161-1 170-24161-2 170-24161-3
65' 170-24162-1 170-24162-2 170-24162-3
70' 170-24163-1 170-24163-2 170-24163-3
75' 170-24164-1 170-24164-2 170-24164-3
80' 170-24165-1 170-24165-2 170-24165-3
85' 170-24166-1 170-24166-2 170-24166-3
90' 170-24167-1 170-24167-2 170-24167-3
95' 170-24168-1 170-24168-2 170-24168-3
100' 170-24169-1 170-24169-2 170-24169-3
175' 170-24216-1 170-24216-2 170-24216-3
chart252
5' 185-00027 -1 185-00027-2 185-00027-3
10' 185-00028-1 185-00028-2 185-00028-3
15' 185-00029-1 185-00029-2 185-00029-3
20' 185-00030-1 185-00030-2 185-00030-3
25' 185-00031-1 185-00031-2 185-00031 -3
30' 185-00032-1 185-00032-2 185-00032-3
35' 185-00033-1 185-00033-2 185-00033-3
40' 185-00034-1 185-00034-2 185-00034-3
45' 185-00035-1 185-00035-2 185-00035-3
50' 185-00036-1 185-00036-2 185-00036-3
55' 185-00037-1 185-00037-2 185-00037-3
60' 185-00038-1 185-00038-2 185-00038-3
65 ' 185-00039-1 185-00039-2 185-00039-3
70' 185-00040-1 185-00040-2 185-00040-3
75' 185-00041-1 185-00041 -2 185-00041 -3
80' 185-00042-1 185-00042-2 185-00042-3
85' 185-00043-1 185-00043-2 185-00043-3
90' 185-00044-1 185-00044-2 185-00044-3
95' 185-00045-1 185-00045-2 185-00045-3
100' 185-00046-1 185-00046-2 185-00046-3
chart253
5' 185-00121-1 185-00121-2
10' 185-00122-1 185-00122-2
15' 185-00123-1 185-00123-2
20' 185-00124-1 185-00124-2
25' 185-00125-1 185-00125-2
30' 185-00126-1 185-00126-2
35' 185-00127-1 185-00127-2
40' 185-00128-1 185-00128-2
45' 185-00129-1 185-00129-2
50' 185-00130-1 185-00130-2
55' 185-00131-1 185-00131-2
60' 185-00132-1 185-00132-2
65' 185-00133-1 185-00133-2
70' 185-00134-1 185-00134-2
75' 185-00135-1 185-00135-2 -
80' 185-00136-1 185-00136-2
85' 185-00137-1 185-00137-2
90' 185-00138-1 185-00138-2 -
95' 185-00139-1 185-00139-2 -
100' 185-00140-1 185-00140-2
460-00018
chart254
5' 185-00413-1 185-00413-2 185-00413-3
10' 185-00414-1 185-00414-2 185-00414-3
15' 185-00415-1 185-00415-2 185-00415-3
20' 185-00416-1 185-00416-2 185-00416-3
25' 185-00417-1 185-00417-2 185-00417-3
30' 185-00418-1 185-00418-2 185-00418-3
35' 185-00419-1 185-00419-2 185-00419-3
40 ' 185-00420-1 185-00420-2 185-00420-3
45 ' 185-00421 -1 185-00421-2 185-00421-3
50 ' 185-00422-1 185-00422-2 185-00422-3
55 ' 185-00423-1 185-00423-2 185-00423-3
60' 185-00424-1 185-00424-2 185-00424-3
65' 185-00425-1 185-00425-2 185-00425-3
70' 185-00426-1 185-00426-2 185-00426-3
75' 185-00427 -1 185-00427-2 185-00427-3
80' 185-00428-1 185-00428-2 185-00428-3
85' 185-00429-1 185-00429-2 185-00429-3
90' 185-00430-1 185-00430-2 185-00430-3
95' 185-00431-1 185-00431-2 185-00431-3
100' 185-00432-1 185-00432-2 185-00432-3
chart255
5' 180-00143-1 180-00143-2 180-00143-3
10' 180-00144-1 180-00144-2 180-00144-3
15' 180-00145-1 180-00145-2 180-00145-3
20' 180-00146-1 180-00146-2 180-00146-3
25' 180-00147-1 180-00147-2 180-00147-3
30' 180-00148-1 180-00148-2 180-00148-3
35' 180-00149-1 180-00149-2 180-00149-3
40' 180-00150-1 180-00150-2 180-00150-3
45' 180-00151-1 180-00151-2 180-00151-3
50' 180-00152-1 180-00152-2 180-00152-3
55' 180-00153-1 180-00153-2 180-00153-3
60' 180-00154-1 180-00154-2 180-00154-3
65 ' 180-00155-1 180-00155-2 180-00155-3
70' 180-00156-1 180-00156-2 180-00156-3
75' 180-00157-1 180-00157-2 180-00157-3
80' 180-00158-1 180-00158-2 180-00158-3
85' 180-00159-1 180-00159-2 180-00159-3
90' 180-00160-1 180-00160-2 180-00160-3
95' 180-00161-1 180-00161-2 180-00161-3
100' 180-00162-1 180-00162-2 180-00162-3
chart256
5' 180-00163-1 180-00163-2 -
10' 180-00164-1 180-00164-2 -
15' 180-00165-1 180-00165-2 -
20' 180-00166-1 180-00166-2 -
25' 180-00167-1 180-00167-2 -
30' 180-00168-1 180-00168-2 -
35' 180-00169-1 180-00169-2 -
40' 180-00170-1 180-00170-2 -
45' 180-00171-1 180-00171-2 -
50' 180-00172-1 180-00172-2 -
55' 180-00173-1 180-00173-2 -
60' 180-00174-1 180-00174-2 -
65 ' 180-00175-1 180-00175-2 -
70' 180-00176-1 180-00176-2 -
75' 180-00177-1 180-00177-2 -
80' 180-00178-1 180-00178-2 -
85' 180-00179-1 180-00179-2 -
90' 180-00180-1 180-00180-2 -
95' 180-00181-1 180-00181-2 -
100' 180-00182-1 180-00182-2
chart257
180-00189
180-0020S
180-00190
180-00206
