Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gearhead Replacements - PG & RA Series Gearhead Specs and Upgrade Option
  • Gearheads-
The PG & RA series gearheads are legacy Bayside gearheads. These used straight-cut through-hardened gears. The PG & RA series gearheads are no longer available.
Related FAQ: PG & RA Recommended Replacements
Attached are specs and dimensions: PG & RA series specs and dimensions
AutoCAD Drawings:
PG series DXF Drawings (zip)
RA series DXF Drawings (zip)
The direction of the output varied depending upon the ratio, where as the Stealth (PS, RS, PX, RX series) is always the same: Shaft Rotation
Related FAQ:  Gearhead Rotation Direction
The newer & better Stealth series gearboxes, the PX and RX series gearheads. These have the same output face dimensions of the PG and RA, but with different dimensions for the body of the gearhead.
example: PG60-005 could be replaced by PX60-005-S2
example: PG115-015 could be replaced by PX115-015-S2
The PX and RX series gearheads have the same output face dimensions (shaft diameter and length, pilot diameter and depth, and bolt circle and through-hole) as a bolt on replacement for the PG and RA series.
The PX and RX series have Stealth technology with plasma-nitride helical gears allowing longer life, higher accuracy and quieter operation. They also have angular contact bearings supporting the shafts for high axial and sideload/radial load capacity.
The PX and RX series offer superior performance in better pricing and leadtime than the PG & RA series.
PG_Replacements.pdf
RA_Replacements.pdf
Or, use this spreadsheet to select the gearhead model, frame and ratio to lookup the replacement.
The mounting kit is a separate section. Select the old mounting kit part number to find the mounting kit for the new gearhead.
Legacy-GH-Crossref.xlsx
We also offer a custom modification of the higher torque and accuracy PS and RS series gearheads  with modified output face and shaft to match the old PG & RA dimensions. This is designated by a -010 as the custom number after the ratio in the part number. This is a common custom we offer not adding significantly to the price or leadtime.
The Stealth series are rated at much longer life and will be quieter, both due to the helical gears, improved design. Because of the plasma nitride surface treatment, they will also withstand any shock loads better.
example: PG60-005 could be replaced by PS60-005-010S2
example: PG180-015 could be replaced by PS180-015-010SH
PS with PG face Drawings (pdf)
RS with RA face Drawings (pdf)
Mounting Kits
The PG & RA series gearheads used the MB mounting kits.
The PX and PS & RX and RS series Stealth Gen II use the MU mounting kits (60, 90, 115 and PS/RS142)
The PS series Stealth Gen I use the MT mounting kits (180 and 220 sizes)
The RS series Stealth Gen I use the MT mounting kits (RX142,180 and 220 sizes)
The PX series Stealth Gen I use the MX mounting kits (PX142 size)
To find the appropriate mounting kit, use the motor manufacturer and model number with the web-base mounting kit search tool: Gearhead Mounting Kit Search Tool
Note some PG & RA series gearheads have the ratio in the mounting kit part number. Example MB142-010-078 would've been on a 10:1 ratio but would be ordered as a MB142-078. The MB mounting kits are the rear half of the gearhead and need to be specified when ordering. They are ordered as a second line item to the gearhead but come attached with the gearhead and include the hardware to fit the motor to the gearhead.
Note the 3:1 for the RA series right-angle gearheads are obsolete. The RB series MultiDrive gearhead is offered in a 3:1 ratio:
Stealth Gearhead "Right Angle" MultiDrive
The RA has a 8:1 ratio. The RS can be done with a 8:1 as custom and has been done in the past. Contact your local distributor for a custom gearhead quote request from our extranet.
1326AB-RPA15-21
1326AB-RPB10-11
1326AB-RPB50-21
F01006
MB115-010
MB60-005
NE23-030-063
NE56-002
NE56-003
NE56-003-LB
NE56-005
NE56-005-019-LB
NE56-010
NE56-010-001
NE56-010-020
NE56-010-LB
NE56-015
NE56-015-LB
NE56-025
NE56-025-LB
NE56-030
NE56-040
NR56-001-007
NR56D-003
NR56D-010
NR56E-005
NR56E-040
NR56S-001
NR56S-005
NR56S-010
NR56S-015
NR56S-015-LB
NR56S-025
PA180-010
PA90-020
PG11-020
PG1115--050
PG115-003
PG115-003-028
PG115-003-075
PG115-003-M10
PG115-005
PG115-005-020
PG115-005-022
PG115-005-028
PG115-005-032
PG115-005-043
PG115-005-043LB
PG115-005-DEMO
PG115-005-LB
PG115-007-043
PG115-008
PG115-008-043
PG115-008-077
PG115-010
PG115-010-017
PG115-010-028
PG115-010-030-LB
PG115-010-030LB
PG115-010-042
PG115-010-054LB
PG115-010-062
PG115-010-076
PG115-010-078
PG115-010-LB
PG115-010-T01
PG115-015
PG115-015-006
PG115-015-047
PG115-015-070
PG115-015-075
PG115-015-LB
PG115-020
PG115-020-011
PG115-020-024
PG115-020-072
PG115-020-074
PG115-020-LB
PG115-020-T01
PG115-030
PG115-030-012LB
PG115-030-024
PG115-030-050
PG115-030-066
PG115-030-073
PG115-030-LB
PG115-040
PG115-040-024
PG115-050
PG115-050-030
PG115-050-031
PG115-050-043
PG115-050-070
PG115-050-LB
PG115-050-T01
PG115-060-014
PG115-060-037LB
PG115-060-LB
PG115-080-058-LB
PG115-100
PG115-100-LB
PG115-100-T01
PG115-150-041
PG115-180-058-LB
PG115-180-058LB
PG115-225
PG115-225-026
PG142--100-LB
PG142-003
PG142-003-067
PG142-003-LB
PG142-005
PG142-005-011
PG142-005-016
PG142-005-059
PG142-005-LB
PG142-005-M02
PG142-006-068
PG142-008
PG142-008-041
PG142-008-058
PG142-008-072
PG142-010
PG142-010-037
PG142-010-068
PG142-010-LB
PG142-015
PG142-015-LB
PG142-020
"""PG142-020- NEW GREASE"""
PG142-020-065
PG142-020-066
PG142-020-LB
PG142-030
PG142-030-037
PG142-030-042
PG142-030-042-LB
PG142-030-042LB
PG142-030-069LB
PG142-030-LB
PG142-040
PG142-050
PG142-050-003-LB
PG142-050-003LB
PG142-050-035
PG142-050-036
PG142-050-062
PG142-050-069
PG142-050-LB
PG142-100
PG142-100-037
PG142-100-070
PG142-100-LB
PG142-100-T01
PG142-100LB
PG142005-011
PG142050-LB
PG15-030
PG180-003
PG180-003-003
PG180-003-013
PG180-004
PG180-004-003
PG180-004-LB
PG180-005
PG180-005-003
PG180-005-005LB
PG180-005-031
PG180-005-LB
PG180-008
PG180-008-039
PG180-008-0390
PG180-008-LB
PG180-010
PG180-010-017
PG180-010-024LB
PG180-010-042-LB
PG180-010-LB
PG180-010LB
PG180-012-LB
PG180-015
PG180-015-008
PG180-015-008-LB
PG180-015-008LB
PG180-015-024
PG180-015-032
PG180-015-032-LB
PG180-015-032LB
PG180-015-044LB
PG180-015-LB
PG180-020
PG180-020-LB
PG180-030
PG180-030-015
PG180-030-024-LB
PG180-030-024LB
PG180-030-LB
PG180-050
PG180-050-008
PG180-050-008LB
PG180-050-009
PG180-050-022
PG180-050-033
PG180-050-036
PG180-050-036LB
PG180-050-LB
PG180-07.5-014
PG180-100
PG180-100-040
PG180-100-LB
PG220-008
PG220-010
PG220-010-001
PG220-010-017
PG220-010-018
PG220-010-LB
PG220-015
PG220-020
PG220-030
PG220-030-016
PG220-030-LB
PG220-050-004
PG220-050-013LB
PG220-100
PG220-100-LB
PG220S-003-001
PG60-003
PG60-003-018
PG60-003-066
PG60-003-LB
PG60-005
PG60-005-006
PG60-005-018
PG60-005-066
PG60-005-067-LB
PG60-005-076
PG60-005-LB
PG60-008
PG60-008-031
PG60-008-084
PG60-008-093
PG60-010
PG60-010-016
PG60-010-018
PG60-010-031
PG60-010-052-LB
PG60-010-082
PG60-010-083
PG60-010-091
PG60-010-092
PG60-010-LB
PG60-015
PG60-015-003
PG60-015-018
PG60-015-057
PG60-015-LB
PG60-015-T03
PG60-020
PG60-020-018
PG60-020-022-LB
PG60-020-022LB
PG60-020-030-LB
PG60-020-030LB
PG60-020-049
PG60-020-050
PG60-020-054
PG60-020-070
PG60-020-085
PG60-020-LB
PG60-030
PG60-030-018
PG60-030-074
PG60-030-074-LB
PG60-030-LB
PG60-030-T01
PG60-050
PG60-050--074-LB
PG60-050-011
PG60-050-011-LB
PG60-050-018
PG60-050-031
PG60-050-059
PG60-050-074
PG60-050-074-LB
PG60-050-LB
PG60-050-T01
PG60-100
PG60-100-LB
PG60V-010-046
PG9--005-LB
PG90-003
PG90-003-058
PG90-003-104
PG90-003-LB
PG90-005
PG90-005-008
PG90-005-030
PG90-005-032
PG90-005-058
PG90-005-064
PG90-005-067
PG90-005-104
PG90-005-LB
PG90-007-088
PG90-008
PG90-008-097-LB
PG90-008-097LB
PG90-008-LB
PG90-008-T01
PG90-010
PG90-010-008
PG90-010-030
PG90-010-052
PG90-010-058
PG90-010-059
PG90-010-064
PG90-010-102
PG90-010-DEMO
PG90-010-F01
PG90-010-LB
PG90-010-T01
PG90-010LB
PG90-015
PG90-015-011
PG90-015-030
PG90-015-067
PG90-015-084
PG90-015-091
PG90-015-111
PG90-015-LB
PG90-015-T01-LB
PG90-020
PG90-020-008
PG90-020-036-LB
PG90-020-060
PG90-020-112
PG90-020-LB
PG90-020-M01
PG90-020-T01
PG90-030
PG90-030-038-LB
PG90-030-063-LB
PG90-030-094
PG90-030-105
PG90-030-110
PG90-030-111
PG90-030-115
PG90-030-116
PG90-030-LB
PG90-030-T01-LB
PG90-050
PG90-050-047-LB
PG90-050-067
PG90-050-087
PG90-050-094
PG90-050-100
PG90-050-187
PG90-050-LB
PG90-050-T01
PG90-100
PG90-100-008
PG90-100-008-LB
PG90-100-045
PG90-100-068-LB
PG90-100-100
PG90-100-107
PG90-100-LB
PG90-100-T02
PG90-180
PG90-=015-111
PGH115-005-049
PL23-100-M005
PL34-005-M005
PL34-005-M006
PL34-050-M005
PL42-050-M001
PL42-050-M063
PL60-010-M133
PL60-100-M005
PR23-050-M005
PR34-005-M005
PS180-100-M105
PS40-004
PS40-004-SH
PS40-005
PS40-005-014
PS40-005-015
PS40-005-SD
PS40-005-SH
PS40-007-SH
PS40-010
PS40-010-012
PS40-010-SD
PS40-010-SH
PS40-020-SD
PS40-025
PS40-025-SD
PS40-025-SH
PS40-040-SU
PS40-050-SH
PS40-050-SU
PS40-100
PS40-100-020
PS40-100-SH
PS40-100-SU
P;142-050
R90-020
RA092-005-M01
RA115-003
RA115-005
RA115-005-017
RA115-005-023LB
RA115-005-032
RA115-005-050
RA115-005-058
RA115-005-LB
RA115-005-T01
RA115-005LB
RA115-008
RA115-008-017LB
RA115-008-LB
RA115-010
RA115-010-013
RA115-010-017
RA115-010-023
RA115-010-027
RA115-010-LB
RA115-015
RA115-015-017-LB
RA115-015-017LB
RA115-015-040
RA115-015-053
RA115-015-LB
RA115-015-T01
RA115-015-TO1
RA115-020
RA115-020-004
RA115-020-007
RA115-020-007LB
RA115-020-016
RA115-020-017
RA115-020-052
RA115-020-053LB
RA115-020-059
RA115-020-LB
RA115-030
RA115-030-019
RA115-030-043
RA115-030-049LB
RA115-030-LB
RA115-040
RA115-050
RA115-050-LB
RA115-050-T01
RA115-100
RA115-100-033
RA115-100-LB
RA115-100-T01LB
RA115010
RA142-003
RA142-003-006
RA142-004-006
RA142-005
RA142-005-005
RA142-005-029
RA142-005-037
RA142-005-039
RA142-005-055
RA142-005-058
RA142-005-LB
RA142-008
RA142-008-031
RA142-008-045
RA142-008-LB
RA142-010
RA142-010-025
RA142-010-048
RA142-010-054-LB
RA142-010-056
RA142-010-057
RA142-010-LB
RA142-014-040
RA142-015
RA142-015-040
RA142-015-050
RA142-015-LB
RA142-020
RA142-020-005
RA142-020-036
RA142-020-051
RA142-020-052
RA142-020-LB
RA142-020-T01
RA142-030
RA142-030-013LB
RA142-030-047
RA142-030-LB
RA142-035
RA142-040
RA142-040-LB
RA142-050
RA142-050-034
RA142-050-059
RA142-050-LB
RA142-100
RA142-100-023
RA142-100-LB
RA142-100-T01
RA142-100-T02
RA180-003-008
RA180-003-015
RA180-004-008
RA180-005
RA180-005-008
RA180-005-015
RA180-005-017
RA180-005-018-LB
RA180-005-018LB
RA180-005-026
RA180-005-028LB
RA180-005-LB
RA180-008
RA180-008-LB
RA180-010
RA180-010-008-LB
RA180-010-008LB
RA180-010-009
RA180-010-022
RA180-010-LB
RA180-014
RA180-015
RA180-015-024-LB
RA180-015-024LB
RA180-015-LB
RA180-015-T03
RA180-020
RA180-020-010
RA180-020-LB
RA180-030
RA180-030-LB
RA180-050
RA180-050-027
RA180-050-LB
RA180-080
RA180-10
RA180-100
RA180-100-023
RA180-100-LB
RA220-005
RA220-005-006
RA220-010
RA220-010-003
RA220-015
RA220-020
RA220-020-005
RA220-030
RA220-030-LB
RA220-100
RA60-003
RA60-003-003
RA60-003-048
RA60-005
RA60-005-003
RA60-005-051
RA60-005-066
RA60-005-069-LB
RA60-005-078
RA60-005-LB
RA60-005-T01
RA60-005-TO1
RA60-006-080
RA60-008
RA60-008-LB
RA60-010
RA60-010-003
RA60-010-029-LB
RA60-010-060
RA60-010-066
RA60-010-077
RA60-010-091
RA60-010-LB
RA60-010LB
RA60-015
RA60-015-018
RA60-015-040
RA60-015-LB
RA60-020
RA60-020-003
RA60-020-036
RA60-020-053
RA60-020-063-LB
RA60-020-079-LB
RA60-020-LB
RA60-020-T01
RA60-030
RA60-030-054
RA60-030-LB
RA60-030-T01
RA60-050
RA60-050-003
RA60-050-053
RA60-050-073
RA60-050-074
RA60-050-085
RA60-050-LB
RA60-050-T01
RA60-100
RA60-100-053
RA60-100-076
RA60-100-LB
RA60-100-T01
RA90--030
RA90-003-001
RA90-003-011
RA90-005
RA90-005-011
RA90-005-011-LB
RA90-005-063-LB
RA90-005-074-LB
RA90-005-079-LB
RA90-005-LB
RA90-005-T01
RA90-008
RA90-008-001
RA90-008-011
RA90-008-053
RA90-008-LB
RA90-010
RA90-010-001
RA90-010-011
RA90-010-028-LB
RA90-010-030-LB
RA90-010-076-LB
RA90-010-076LB
RA90-010-084
RA90-010-LB
RA90-010-T01
RA90-015
RA90-015-008
RA90-015-064
RA90-015-074-LB
RA90-015-077
RA90-015-LB
RA90-016
RA90-020
RA90-020-011
RA90-020-014
RA90-020-031
RA90-020-036
RA90-020-051
RA90-020-057
RA90-020-DEMO
RA90-020-LB
RA90-020-T01
RA90-030
RA90-030-008
RA90-030-046
RA90-030-047
RA90-030-051
RA90-030-077
RA90-030-078
RA90-030-LB
RA90-030-T01
RA90-030-T01-LB
RA90-050
RA90-050-037
RA90-050-LB
RA90-050-T01
RA90-100
RA90-100-037
RA90-100-077-LB
RA90-100-084
RA90-100-084LB
RA90-100-LB
RA90-100-T01
RA90-100-T01-LB
RA90-20
RB115-001
RB220-002-002
RPR02-PG
SE56-005-M019
PS115-003-010
PS115-003-010LH
PS115-003-010L2
PS115-003-010SD
PS115-003-010SH
PS115-003-010SU
PS115-003-010S2
PS115-004-010
PS115-005-010
PS115-005-010-X2
PS115-005-010LH
PS115-005-010SD
PS115-005-010SH
PS115-005-010SU
PS115-005-010S2
PS115-005-010W01
PS115-007-010
PS115-007-010-X2
PS115-007-010SH
PS115-007-010SU
PS115-007-010S2
PS115-010-010
PS115-010-010LH
PS115-010-010L2
PS115-010-010SD
PS115-010-010SH
PS115-010-010SU
PS115-010-010S2
PS115-010-010X2
PS115-015-010
PS115-015-010-X2
PS115-015-010LH
PS115-015-010SH
PS115-015-010SU
PS115-015-010S2
PS115-020-010
PS115-020-010-X2
PS115-020-010SH
PS115-020-010SU
PS115-020-010S2
PS115-030-010
PS115-030-010-X2
PS115-030-010LH
PS115-030-010L2
PS115-030-010SH
PS115-030-010SU
PS115-030-010S2
PS115-030-010X2
PS115-040-010
PS115-040-010SH
PS115-050-010
PS115-050-010LH
PS115-050-010L2
PS115-050-010SH
PS115-050-010S2
PS115-100-010
PS115-100-010SD
PS115-100-010SH
PS115-100-010SU
PS142-003-010
PS142-003-010LH
PS142-003-010SH
PS142-004-010
PS142-004-010SH
PS142-005-010
PS142-005-010-F01
PS142-005-010F01
PS142-005-010F01SH
PS142-005-010LH
PS142-005-010SH
PS142-010-010
PS142-010-010SH
PS142-010-010SU
PS142-015-010
PS142-015-010LH
PS142-015-010SH
PS142-020-010
PS142-020-010LH
PS142-020-010SH
PS142-020-010SU
PS142-03-010
PS142-030-010
PS142-030-010SH
PS142-050-010
PS142-050-010-LH
PS142-050-010-X2
PS142-050-010LH
PS142-050-010LU
PS142-050-010L2
PS142-050-010SH
PS180-003-010
PS180-003-010LD
PS180-003-010LH
PS180-003-010SD
PS180-003-010SH
PS180-004-010
PS180-004-010LH
PS180-004-010SH
PS180-005-010
PS180-005-010LH
PS180-005-010SH
PS180-007-010
PS180-007-010LH
PS180-010-010
PS180-010-010LH
PS180-010-010SH
PS180-010-010SU
PS180-015-010
PS180-015-010LH
PS180-015-010LU
PS180-015-010SH
PS180-015-010SU
PS180-020-010
PS180-020-010SH
PS180-020-010SU
PS180-025-010
PS180-025-010SH
PS180-03-010
PS180-030-010
PS180-030-010LU
PS180-030-010SH
PS180-030-010SU
PS180-050-010
PS180-050-010LH
PS180-050-010LU
PS180-050-010SH
PS180-050-010SU
PS220-005-010
PS220-010-010
PS220-010-010SD
PS220-010-010SH
PS220-015-010
PS220-015-010LH
PS220-015-010SH
PS220-030-010
PS220-030-010SH
PS60-003-010
PS60-004-010
PS60-004-010SU
PS60-005-010
PS60-005-010-X2
PS60-005-010LH
PS60-005-010SH
PS60-005-010SU
PS60-005-010S2
PS60-007-010
PS60-007-010SH
PS60-010-010
PS60-010-010LH
PS60-010-010SD
PS60-010-010SH
PS60-010-010SU
PS60-015-010
PS60-015-010-X2
PS60-015-010L2
PS60-020-010
PS60-020-010LH
PS60-020-010LU
PS60-020-010SD
PS60-020-010SH
PS60-020-010SU
PS60-030-010
PS60-030-010SU
PS60-050-010
PS60-050-010SH
PS60-100-010
PS60-100-010-X2
PS60-100-010L2
PS60-100-010SD
PS60-100-010SH
PS60-100-010S2
PS90-003-010
PS90-003-010-X2
PS90-003-010SD
PS90-003-010SH
PS90-003-010S2
PS90-005-010
PS90-005-010-X2
PS90-005-010LH
PS90-005-010SH
PS90-005-010S2
PS90-010-010
PS90-010-010-X2
PS90-010-010LH
PS90-010-010SD
PS90-010-010SH
PS90-010-010SU
PS90-010-010S2
PS90-015-010
PS90-015-010SH
PS90-015-010SU
PS90-020-010
PS90-020-010-X2
PS90-020-010SD
PS90-020-010SH
PS90-020-010S2
PS90-025-010
PS90-025-010-X2
PS90-025-010SH
PS90-025-010S2
PS90-030-010
PS90-030-010-X2
PS90-030-010SH
PS90-030-010SU
PS90-030-010S2
PS90-050-010
PS90-050-010-X2
PS90-050-010SD
PS90-050-010SH
PS90-050-010SU
PS90-050-010S2
PS90-100-010
PS90-100-010SH
PS90-100-010SU
RS115-005-010
RS115-005-010SH
RS115-010-010
RS115-010-010-X2
RS115-010-010LB
RS115-010-010LE
RS115-010-010LF
RS115-010-010LH
RS115-010-010SE
RS115-010-010SF
RS115-010-010SH
RS115-010-010SU
RS115-010-010S2
RS115-015-010
RS115-015-010F01S2
RS115-015-010LU
RS115-015-010SE
RS115-015-010SH
RS115-015-010SU
RS115-015-010S2
RS115-020-010
RS115-020-010-X2
RS115-020-010LF
RS115-020-010LU
RS115-020-010L2
RS115-020-010SD
RS115-020-010S2
RS115-025-010
RS115-025-010LF
RS115-025-010W01
RS115-025-010W01SH
RS115-030-010
RS115-030-010-X2
RS115-030-010LD
RS115-030-010LF
RS115-030-010LU
RS115-030-010L2
RS115-030-010SF
RS115-040-010
RS115-040-010SU
RS115-050-010
RS115-050-010-S2
RS115-050-010-X2
RS115-050-010L2
RS115-050-010SF
RS115-050-010SH
RS115-050-010SU
RS115-050-010S2
RS142-005-010
RS142-005-010LH
RS142-005-010LU
RS142-005-010SE
RS142-008-010
RS142-008-010SE
RS142-008-010SF
RS142-008-010SH
RS142-008-010SU
RS142-008-010SX
RS142-010-010
RS142-010-010LU
RS142-010-010SD
RS142-010-010SE
RS142-010-010SF
RS142-010-010SH
RS142-015-010
RS142-015-010LF
RS142-015-010LU
RS142-020-010
RS142-020-010-F01
RS142-020-010F01SH
RS142-020-010SE
RS142-020-010SH
RS142-030-010
RS142-030-010-X2
RS142-030-010SD
RS142-030-010SH
RS142-030-010SU
RS142-030-010S2
RS142-040-010
RS142-040-010F01SH
RS142-040-010LD
RS142-050-010
RS142-050-010-X2
RS142-050-010F01
RS142-050-010F01SH
RS142-050-010LE
RS142-050-010LF
RS142-050-010LU
RS142-050-010L2
RS142-050-010SE
RS142-050-010SF
RS142-100-010
RS142-100-010LH
RS180-005-010
RS180-005-010LH
RS180-005-010SH
RS180-005-010SU
RS180-015-010
RS180-015-010LU
RS180-015-010SE
RS180-020-010
RS180-020-010SE
RS180-020-010SU
RS180-030-010
RS180-030-010SH
RS180-030-010SU
RS180-050-010
RS180-050-010LD
RS180-050-010SH
RS180-050-010SU
RS220-010-010
RS220-010-010SE
RS220-010-010SF
RS220-010-010SH
RS220-030-010
RS220-030-010LH
RS60-005-010
RS60-005-010SH
RS60-005-010SU
RS60-010-010
RS60-010-010LF
RS60-010-010SF
RS60-010-010SH
RS60-020-010
RS60-020-010-X2
RS60-020-010LH
RS60-020-010LU
RS60-020-010L2
RS60-020-010S2
RS60-030-010
RS60-030-010-X2
RS60-030-010L2
RS60-030-010SF
RS60-050-010
RS60-050-010LH
RS60-050-010L2
RS60-050-010SH
RS60-100-010
RS60-100-010-X2
RS60-100-010L2
RS60-100-010SD
RS60-100-010S2
RS90-005-010
RS90-005-010-X2
RS90-005-010SE
RS90-005-010SH
RS90-005-010S2
RS90-010-010
RS90-010-010LE
RS90-010-010LH
RS90-010-010SD
RS90-010-010SE
RS90-010-010SH
RS90-015-010
RS90-015-010SU
RS90-020-010
RS90-020-010SH
RS90-030-010
RS90-030-010-X2
RS90-030-010SF
RS90-030-010SH
RS90-030-010SU
RS90-030-010S2
RS90-050-010
RS90-050-010LH
RS90-050-010L2
RS90-050-010SF
RS90-050-010SH
RS90-050-010SU
RS90-050-010S2
RS90-100-010
RS90-100-010LD
RS90-100-010SH
