Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cables to connect GM motors to Parker Drives
    • Aries Drive (Discontinued)-
      • Controller (CE)+
      • Drive only (AE,AR, SE, SR)+
      • EPL+
      • Aries Brake Delay
      • E27 Bridge Hardware Fault
      • Manual Alignment Procedure
      • Aries drive won't enable
      • Selecting a Fuse
Note: The length of the cable can be ordered with the length at the end of the below part number in millimeters, such as 10963330-3000
Standard lengths are 600, 1000, 2000, 3000, 6000, 9000 and 10000 millimeters.
Bayside GM motor to Parker Drive Cables
Drive Part Number Notes Feedback Cable
Part No.
Power Cable
Part No.
Compax3
  • S025V2F12
  • S038V4F12
  • S063V2F12
  • S075V4F12
  • S150V4F12
  • S300V4F12
  • 2.5 amp 120 - 240 VAC Encoder
  • 3.8 amp 208 - 480 VAC Encoder
  • 6.3 amp 120 - 240 VAC Encoder
  • 7.5 amp 208 - 480 VAC Encoder
  • 15 amp 208 - 480 VAC Encoder
  • 30 amp 208 - 480 VAC Encoder
  • 10963330
  • 10963330
  • 10963330
  • 10963330
  • 10963330
  • 10963330
  • 10963093
  • 10963093
  • 10963093
  • 10963093
  • 10963093
  • High Current
    Aries
  • AR01AE
  • AR02AE
  • AR04AE
  • AR08AE
  • AR13AE
  • AR20AE
  • AR30AE
  • 1 amp 120 - 240 VAC Encoder
  • 1.75 amp 120 - 240 VAC Encoder
  • 3 amp 120 - 240 VAC Encoder
  • 4.5 amp 120 - 240 VAC Encoder
  • 10 amp 120 - 240 VAC Encoder
  • 16 amp 120 - 240 VAC Encoder
  • 10963335
  • 10963335
  • 10963335
  • 10963335
  • 10963335
  • 10963335
  • 10963335
  • 10963093
  • 10963093
  • 10963093
  • 10963093
  • 10963093
  • High Current
  • High Current
    Gemini
  • GVnn-L3E
  • GVnn-U3E
  • GVnn-U6E
  • GVnn-U12E
  • GVnn-H20E
  • 3 amp cont 170/340 VDC encoder
  • 6 amp cont 170/340 VDC encoder
  • 12 amp cont 170/340 VDC encoder
  • 20 amp cont 295/340 VDC encoder
  • 10963254
  • 10963254
  • 10963254
  • 10963254
  • 10963254
  • 10963268
  • 10963268
  • 10963268
  • 10963268
  • High Current
    For High Current and resolver cables, these are available as custom. Please contact Bayside Applications Engineering for quote or submit custom Bayside quote request in extranet for ATCs.
    The ViX feedback cable pinout is the same as the Aries, so the same feedback cable could be used with the ViX drives.
    The flying lead feedback cable is 10963123, as an example for ordering the part number is 10963123-3000
