Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cables - PS Connector Specifications
The PS wiring option for the SM, BE, Neometric, J Series, M-Series, SMN, and MaxPlus MPM (MPF) Option 5 is the preferred cabling option for the IPA, Compax3, Vix, Aries and Gemini drives. It is standard on the newer MPP/MPJ/MPW motors.
For Pinout information, click here.
For further specifications, email applications at emn_support@parker including the motor part number.
PS Connector Dimensions
Please see motor product pages for dimension drawings or for the MPP/MPJ catalog pages have the dimensions for the connectors. Please contact factory if there's any further questions.
PS_and_LC_Connector_Vendor_Information
PS connector  LC connector
glh updated 11/2016
UPDATED 02FEB20221 DCLIFFE -- Fixed link and added metadata.
  • connector
  • PS
