Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base General - Minimum temperature of the Servo motors
The minimum operating temperature Compumotor Servo motors is as follows
Motor Size Feedback Min Temp
All SM, BE, N, J, M Resolver -30°C
All SM, BE, N, J, M Encoder 0°C
All Integrated Gearheads Resolver -25°C
All MPP Rotary Encoder or Resolver 0°C
All MPM Rotary Encoder or Resolver 0°C
All APEX and Z Resolver -20°C
Custom motors can be ordered that will run at lower temperatures
The limitiation on the resolver motors is not due to the resolver, but the grease in the bearings. If lower temperatures are needed, a custom motor with lower temperature bearings should be requested. For condensing environments, a protective winding coating or vented motor are available as a custom.
Likewise the limitation on the integrated gearheads is the grease in the bearings.
Minimum/Maximum Storage temperatures:
Minimum is -50c non-condensing.
Maximum is 120c for an encoder feedback.
Maximum is 150c for a resolver feedback.
