Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Dynaserv G3 Encoder Resolution
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
Encoder resolutions for the Dynaserv G3 series (post-quadrature):
Motor Model Encoder Resolution#113 (Default)#112 (Default)
DM1A-xxx
4096000 4096000 1024000
DM1B-xxx
2621440 2621440 655360
DM1C-xxx
DR1A-xxx
1638400 1638400 819200
DR1B-xxx
1015808 1015808 507904
DR1E-xxx
1228800 1228800 614400
DM5B-xxx
557056 557056 278528
DR5C-xxx
425984 425984 212992
DR5E-xxx
638976 638976 319488
#112 = drive resolution
#113 = scaling (rarely changed from default)
If #112 or #113 is changed, the changed data becomes valid the next time the drive's power is cycled. A software reset will not do--the physical power must be cycled!
