Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Dynaserv Runout Options
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
Runout and Axial Deviation are the mechanical deviations when the motor is rotating. Runout is the radial deviation of the rotor. Axial deviation is the deviation perpendicular to the axis of rotation. The standard Dynaserv motor specification is 0.1mm for both runout and axial deviation. Improved runout and axial deviation of 0.02mm or 0.01mm or 0.005mm on some models are available as a Custom Product.
Below is a table of the options for each motor.
DM Series Motors Runout Options
Model #0.005mm0.01mm0.02mm
DM-1004BYStandardN/A
DM-1015BYYN/A
DM-1030BYYN/A
DM-1045BYYN/A
DM-1060BN/AYY
DM-1050AYYN/A
DM-1100AYYN/A
DM-1150AYYN/A
DM-1200AYYN/A
Y = Option Avalable
N/A = Option Not available
DR Series Motors Runout Options
DR-1008BN/AN/AN/A
DR-1015BYYN/A
DR-1030BYYN/A
DR-1045BYYN/A
DR-1060BN/AYY
DR-1070EYYN/A
DR-1100EYYN/A
DR-1130EN/AYY
DR-1160EN/AYY
DR-1220EN/AYY
DR-1250EN/AYY
DR-1050AYYN/A
DR-1100AYYN/A
DR-1150AYYN/A
DR-1200AN/AYY
DR-1300AN/AYY
DR-1400AN/AYY
DR-5030BN/AN/AY
DR-5050BN/AN/AY
DR-5070BN/AN/AY
DR-5300AN/AN/AY
DR-5400AN/AN/AY
DR-5500AN/AN/AY
Y = Option Avalable
