Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cables - PS Connector Wiring Pinouts
The PS Connector pinouts are below. Please refer to the PS Connector Specifications and PS Cable Specifications FAQ's for further information on the connectors and cables.
PS Connector Motor Power Pinout
Connector Pin # (Size 1.0) Connector Pin # (Size 1.5) Wire Color Function
1 U Black 1 Phase U
2 V Black 2 Phase V
6 W Black 3 Phase W
3 Earth Green/Yellow Earth
4 + Red/Blue Brake+ (+24 VDC)
5 - Red/Blue Brake- (0 VDC)
PS Feedback Connector Pinouts
Connector Pin # SinCos(Hiperface) Incremental( or Smart) Encoder Resolver
1 SIN- (REFSIN) ENC A- SIN-
2 SIN+ (+SIN) ENC A+ SIN+
3 No Connect No Connect No Connect
4 No Connect Hall 1 or A0 (or CLK+) No Connect
5 Datafbk+ (Data+ RS485) Hall 2 or A1 No Connect
6 Datafbk- (Data- RS485) Hall 3 or A2 (or CLK-) No Connect
7 No Connect Ground No Connect
8 Jumped to Pin 13 +5 VDC No Connect
9 Temp(Thermistor) + Temp(Thermistor) + Temp(Thermistor) +
10 No Connect No Connect No Connect
11 COS+ (+COS) ENC B+ COS+
12 COS- (REFCOS) ENC B- COS-
13 Temp(Thermistor)- Temp(Thermistor) - Temp(Thermistor) -
14 Vcc (Us 7-12 VDC) No Connect REFres+
15 No Connect ENC Z+ No Connect
16 No Connect ENC Z- No Connect
17 GND No Connect REFres- (GND)
