Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cables - PS Cable Specifications
PS cables are braided shielded cables specifically designed for servo applications to help minimize EMI influences in system installations. For PS connector manufacturers and pinouts please refer to the following FAQ's: PS Connector Wiring Pinouts and PS Connector Specifications.
PS Cable Specifications for static installations (i.e., permanently fixed)
Order Number Part Number Cable
Diameter
Min.
Bend
Radius
Conductors Storm Part Number
  • F-1A1-xx
  • F-2B1-xx
  • F-2C1-xx
  • F-3C1-xx
  • F-3D1-xx
  • F-9F1-xx
  • 71-021628-xx
  • 71-021629-xx
  • 71-022231-xx
  • 71-023382-xx
  • 71-023381-xx
  • 71-025010-xx
0.340" 3.40" 10 twisted pair
conductor
x 24 AWG
SPD-21268
P-1A1-xx 71-021626-xx 0.370" 3.70" 4c x 18AWG
2c x 20AWG
SPD-21267
P-3B1-xx 71-021627-xx 0.445" 4.45" 4c x 14AWG
2c x 20AWG
SPD-21401
P-4B1-xx 71-022341-xx 0.470" 4.70" 4c x 12AWG
2c x 20AWG
SPD-21402
P-4B2-xx 71-023383-xx 0.470" 4.70" 4c x 12AWG
2c x 20AWG
SPD-21402
P-6B2-xx 71-023384-xx 0.765" 7.65" 4c x 8AWG
2c x 20AWG
SPD-21532
PS Cable Specifications for Continuous (High) Flex installations (i.e., cable carriers)
Order Number Part Number Cable Diameter Min. Bend Radius Min. Number of Cycles Conductors OEM Part Number
  • FH-1A1-xx
  • FH-2B1-xx
  • FH-2C1-xx
  • FH-3C1-xx
  • FH-3D1-xx
  • FH-9F1-xx
  • 71-025004-xx
  • 71-025001-xx
  • 71-025000-xx
  • 71-025003-xx
  • 71-025002-xx
  • 71-025011-xx
0.488"
0.510"
3.66"
5.10"
>10 million
>5 million
10 twisted pair
conductors x
24 AWG
28917
CF211-02-10-02
PH-1A1-xx 71-025005-xx 0.550" 4.13" >5 million 4c x 18AWG
2c x 22AWG
CF21-07-03-02-02
PH-3B1-xx 71-025006-xx 0.559"
0.830"
4.20"
6.23"
>4 million
>5 million
4c x 14AWG
2c x 17AWG
4c x 14AWG
2c x 16AWG
36371
CF21-25-15-02-02
PH-4B1-xx 71-025007-xx 0.638"
0.910"
4.79"
6.83"
>4 million
>5 million
4c x 12AWG
2c x 17AWG
4c x 12AWG
2c x 16AWG
36372
CF21-40-15-02-02
PH-4B2-xx 71-025008-xx 0.638"
0.910"
4.79"
6.83"
>4 million
>5 million
4c x 12AWG
2c x 17AWG
4c x 12AWG
2c x 16AWG
36372
CF21-40-15-02-02
PH-6B2-xx 71-025009-xx 1.060" 7.95" >5 million 4c x 8AWG
2c x 16AWG
CF21-100-15-02-02
-xx refers to cable length in feet
Blue numbers are for Olflex cables (Alternate Source) - Feedback Cable Jacket color is Gray, Power Cable Jacket Color is Gray
Black numbers are for Igus cables (Primary Source) - Feedback Cable Jacket color is Gray, Power Cable Jacket color is Green.
Manufacturers:
Storm Products Company Igus, Inc. Lapp USA, Olflex Brand
1400 Memorex Drive 50 N. Broadway 29 Hanover Road
Santa Clara, CA 95050 E.Providence, RI 02914 Florham Park, NJ 07932
USA USA USA
Phone: (877) 227-8676 Phone: (800) 521-2747 Phone: (800) 774-3539
Fax: (408) 565-9825 Fax: (401) 438-7270 Fax: (973) 660-9330
Email: interconnect@stormproducts.com E-mail: webmaster@igus.com Email: sales@lappusa.com
