Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base M Motors - MS & PS Mating connector for the M Series Motors
The following table lists the MS mating connector information for the M Series motors.
MS Motor Power Mating Connector Information
Frame Size Compumotor Part Number Amphenol Part Number
M105xxx 43-020109-01 #GT06AF16S-1S(023)
M145xxx 43-020110-01 #GT06AF20-15S(023)
M205xxx 43-020112-01 #GT06AF24-10S(023)
MS Feedback Mating Connector Information
Type Compumotor Part Number Amphenol Part Number
Encoder 43-020113-01 #PT06E-14-15S(023)
Resolver 43-020113-01 #PT06E-14-14S(023)
Manufacturer: Amphenol Corporation
PS Motor Power Mating Connector Information
Frame Size Compumotor Part Number* Intercontec Produkt GmbH Part Number
M105xxx Not Available For Purchase BSTA085FR23580035000
M145xxx Not Available For Purchase BSTA085FR23580035000
M205xxx Not Available For Purchase CSTA264FR49250001000
*The part numbers listed above are for crimp pin style connectors. This requires an expensive special crimping tool. Therefore, Parker has decided not to sell these connectors seperately. There is no solder cup version for the motor power connectors.
PS Feedback Mating Connector Information
Type Compumotor Part Number** Intercontec Produkt GmbH Part Number
Encoder Not Available For Purchase ASTA035FR01610035000
Resolver Not Available For Purchase ASTA035FR01610035000
** The part numbers listed above are for crimp pin style connectors. This requires an expensive special crimping tool. Therefore, Parker has decided not to sell these connectors seperately. There is a solder cup version of the pins available under part number: ASTA035FS04610035000
Manufacturer: Intercontec Produkt GmbH
