Home Parker Community Technologies Electromechanical Group Electromechanical Support Forum Why can't I connect to Drvx3 support tool software (Dynaserv).
  • State Suggested Answer
  • Date nqtuan196@gmail.com
    nqtuan196@gmail.com
  • Date 20 Jun 2020 9:01 AM
  • Replies 2 replies
  • Answers 1 answer
  • Views 1335 views
nqtuan196@gmail.com
By  nqtuan196@gmail.com 6 months ago
Dear all
I had a problem about connect to DRVX3 support tool. I used RS232 diagram as below to connect to my PC.
I Have already had port (Com3) of RS232-USB and Chose DRVG3 Pulse driver type , but i still couldn't turn online DRVX3, it immediately turned back to offline when i clicked online.
Please help me to troubleshoot this issue, I really appreciate your help!
Thank you & Best Regards.
Top Replies
  • Daniel Cliffe
    Daniel Cliffe, Employee 6 months ago +1 suggested
    Good morning. Unfortunately, all Dynaserv products were discontinued several years ago and our ability to support them is limited. However, I can offer you a couple of pointers. I see that you are using...
Parents
  • Daniel Cliffe
    0 Daniel Cliffe, Employee 6 months ago
    I see that you are using a USB-RS232 converter with a Prolific chipset.  What we have found over the years is that these often do not meet our expectations of performance and reliability.  We recommend using USB-RS232 converters with FTDI chipsets instead.  If you need a recommendation, consider using USB-2920 from Cables Unlimited.
    Alternatively, it looks like you have an RS232 port built into your PC (COM 1).  Is there a reason you are not using this one?  Built-in ports usually work better than anything else.
    I also notice you are using Windows 7.  None of the Dynaserv software was ever tested on Windows 7 and there may be issues we do not know about.  Until this January, Windows 7 was also receiving updates, which could result in previously functional software developing problems.
    If you have access to a Windows XP computer or a Windows XP virtual machine, I would recommend giving that a try.  XP is friendlier with older software than 7 is.
    I would also suggest starting to look for a replacement fort this system since the drives and motors can no longer be repaired.  Since most Dynaserv systems were pretty specialized, this is something we would want to talk over.  If you are interested in replacing this, please reach out to us at emn_support@parker.com any time.
    • Up +1 Down
  • nqtuan196@gmail.com
    0 nqtuan196@gmail.com 6 months ago in reply to Daniel Cliffe
    Thank You very much, I have succeeded in connecting to Dynaserv due to CH340 chipset.
Reply
Children
No Data
