Home Parker Community Technologies Electromechanical Group Electromechanical Support Forum Need to jog S83-135S motor using SX series Compumotor drive with toggle switch
  • State Not Answered
  • Date cliff.turnell@cgimotion.com
  • Date 14 Oct 2020 10:51 PM
  • Replies 2 replies
  • Subscribers 3 subscribers
  • Views 768 views
By  cliff.turnell@cgimotion.com 3 months ago
  Hi Group,
  Our company recently purchased a S83-135S motor and Compumotor SX series drive to do some fatigue testing on some of our products. The motor and drive are behaving nicely and my loop program is acting as it should with the motor accelerating, stopping, holding etc. I would like to add a mechanical toggle switch to be able to jog the motor CW when necessary. The way I have the switch wired is G (below FLT) to switch terminal and the other switch terminal to I1 so that when the switch is activated power flows to I1. I also have a jumper wire from I1 to I3 so that when I1 is powered so is I3. In my program I have I1 set as a CW jog input (IN1J) and I3 is set to low (IN3L). I tried to emulate the "jogging the motor " sequence in chapter 4 of the SX/SXF Indexer/Drive User Guide but am getting no movement when I toggle the switch. I did read that 3V was the proper voltage so I have a resistor in between G and my switch resulting in 2.9V at I1 and I3 when the switch is toggled. I am sure there is probably something rudimentary that I am missing but currently I am at a loss, if anyone has any ideas how to resolve this issue I would sincerely appreciate it. Thank you all in advance for your time!
  • William Chin
    0 William Chin, Employee 3 months ago
    Apologies but the SX series has been obsoleted for 15+years, we can only offer minimal support.  It looks like you found the user guide.  The way the Inputs need to be wired up is that Opto2 is the pull up voltage for the input.  Opto2 can be jumpered to the +5V.  Then the input I1-I5 is either going to float(no connected to anything.  This is the off state) or a path to ground(specifically the GND pin on the connector - This is the ON state)
    The main thing is OFF means there is no current flowing from Opto2 to GN through the input and ON is current flowing.  Find the diagram in the User guide under IO wiring section for more details
  • cliff.turnell@cgimotion.com
    0 cliff.turnell@cgimotion.com 3 months ago in reply to William Chin
    Thank you so much for the clarification, I was missing the Opto 2 pull up. Have a great day!
