Home Parker Community Technologies Electromechanical Group Electromechanical Support Forum Ajust PI current loop parameters manually in 590+ DC parker
  • State Not Answered
  • Date Ibrahim-yagoub@hotmail.com
  • Date 21 Dec 2020 3:17 PM
  • Replies 3 replies
  • Views 265 views
By  Ibrahim-yagoub@hotmail.com 26 days ago
Hello everyone,
How we can adjust PI parameters in current regulation loop. ie select the best values if the autotune doesn't work.?
  • Daniel Cliffe
    0 Daniel Cliffe, Employee 25 days ago
    Before trying to do that, I would try to make the autotune work.  Setting these parameters manually is difficult and error-prone.  If autotune fails, consider these troubleshooting tips:
    • Make sure the shaft did not rotate.  If it did, try clamping it down.  This is especially true of permanent magnet or stab shunt wound motors.
    • Run a megohmeter test on your armature to make sure there are no shorts.
    • Make sure you were running an armature current loop autotune and not a field current loop autotune.  Never run a field current loop autotune.
    On the 590+, autotune should always succeed except in certain cases where the motor is very large -- over 500 HP.  Some motors can also be run without autotune.  Are you able to get this motor to run at all?  When you try running without autotune, what kind of fault do you get?
  • Ibrahim-yagoub@hotmail.com
    0 Ibrahim-yagoub@hotmail.com 25 days ago in reply to Daniel Cliffe
    Yes the motor is running without any error but the current seems a little high and the wedding temperature also high. We try to a just this parameters in order to reduce this things. The Autotune procedure it doesn't very clear in the manual. Can you please clarify if it's possible.
  • Daniel Cliffe
    0 Daniel Cliffe, Employee 25 days ago in reply to Daniel Cliffe
    To be clear, you should only attempt to change the PI parameters manually if autotune fails.  If autotune succeeds, then altering the PI gains will not improve performance.
