I have a Digiplan BLX75B drive that is displaying error code 3 (three flashes of the fault LED). I believe this means that the EPROM memory map has changed?
I have tried all three points of the following but this has not cured the problem: community.parker.com/.../error-code-3---memory-map-changed
Can anyone advise if there is any other way of curing this fault?
The unit is communicating via a terminal and the battery is brand new.
Thanks!
