variable flow friction detent
Can anyone tell me where to find a hydraulic valve.
It locks in whatever position you put it until you depress the button. Panel mounted. Variable displacement depending how much you move the valve either direction.
single spool.
Rated for 80 GPM 3,000 psi  to turn large motor. Can turn either direction.
